Old 04-26-2012, 02:05 AM   #1
banifesto
Drives: Yaris Sedan
Hi,
Just wondering.. by adjusting the stiffness, will that make the sway bar less stiff than 22mm.. probably will provide similar stiffness level to a 19mm bar? just curious on how does an adjustable sway bar works..
banifesto is offline   Reply With Quote
Old 04-26-2012, 02:09 PM   #2
Ratz
Ratz's Avatar
Drives: 2011 Yaris 4 Dr. Sedan
Originally Posted by banifesto View Post
Hi,
Here is the link to their website that should shine some light on the subject. http://www.whiteline.com.au/vehicle_swaybars.php
You will see the number of holes in the end of the bar. When you use the hole furthest away from the center of bar (see my photo #2) you get softer response. Hopefully Jeff from Micro Image will confirm this but difference between the holes is like using 23.mm or 19mm bar.
I just changed my setting this morning and it took me about 5 minutes. Have not road tested the car yet. As I said before I found the stiff setting too aggressive for my liking but that may be a good news for demanding drivers.
Ratz
Cleverly disguised as a responsible adult.
Ratz is offline   Reply With Quote
TRD rear sway bar? Lewis DIY / Maintenance / Service 26 09-10-2013 02:10 PM
Yaris Rear Sway Bar Install ? Spork Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 03-20-2012 09:17 PM
My Ultra Racing rear sway bar install CtrlAltDefeat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 49 03-03-2011 02:08 AM
WTB Rear Sway Bar nick.dollimount Willing to Buy by private party 2 05-27-2010 02:44 PM
rear sway bar needed vten Willing to Buy by private party 11 11-22-2009 11:50 PM
