Old 05-10-2012, 12:08 AM   #1
TOLMACH
Drives: soarer
Is it difficult to remove (get rid of) the rear yaris logo?
I am considering removing the yaris logo from the rear hatch door.. I suspect it is attached using some crazy glue or anything.
Is it feasible to have it removed without damage to the door?
Old 05-10-2012, 12:26 AM   #2
catliektheif
catliektheif's Avatar
Drives: 2010 5 Door
oh boy.. before you get grilled... http://www.yarisworld.com/forums/showthread.php?t=938
lol okay
Old 05-10-2012, 12:29 AM   #3
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
Haha, 334 posts and a member for over a year and you're asking such a noob question? You been drinkin'?
That like above pretty much is all there is to it. Fishing line or dental floss works good... and kite string saws through it rather well also!
Old 05-10-2012, 12:38 AM   #4
catliektheif
Drives: 2010 5 Door
i used fishing line and i didnt even have to use a heat gun like in the diy.. but it did help that my car was parked in the sun for a little while before i did it i think.
lol okay
Old 05-10-2012, 02:45 AM   #5
TOLMACH
Drives: soarer
Thanks guys!
Old 05-10-2012, 03:02 AM   #6
TOLMACH
Drives: soarer
In case fishing line or dental floss do not work, I always can use my DeWalt angle grinder.
Old 05-10-2012, 04:20 PM   #7
vadr45
vadr45
vadr45's Avatar
Drives: 2009 Base 3-door
But don't stop there - take it all off - the rear of the hatch looks glorious with no Toyota ads, logos, dealers, etc. Then, if you like, you can add your own, personal logo:
vadr45
Alexandria, VA
2009 Black Base 3-Door Yaris
1950 Austin A70 Hampshire
vadr45 is offline   Reply With Quote
Old 05-10-2012, 04:35 PM   #8
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
Why'd you stop?
-Type 07 FFL-
My odometer 03/11
Old 05-11-2012, 12:48 AM   #9
catliektheif
Drives: 2010 5 Door
i still dont understand how you remove the toyota logo and make it smooth like that
lol okay
Old 05-11-2012, 01:12 AM   #10
TOLMACH
Drives: soarer
+1
Old 05-11-2012, 01:14 AM   #11
TOLMACH
Drives: soarer
I also have already removed the rear wiper.. looks so much better without it ))))))))
http://photo.qip.ru/users/tolmach/96608749/127645223/
Old 05-11-2012, 01:47 AM   #12
mazilla
advocatus diaboli
mazilla's Avatar
Yeah, it makes a huge difference in my opinion, makes the back look wider. I will probably remove the lock/latch when I don't need to access the back as often..
The body shop wanted to cut the hatch and continue the seam straight across as if the emblem was never there...that was a little more than I needed so I declined. It may get done if/when the latch comes off, it just seems like a little too much work for such a minor gain...
-Type 07 FFL-
My odometer 03/11
Old 05-13-2012, 11:56 AM   #13
vadr45
vadr45
vadr45's Avatar
<<Why'd you stop?>>
I like the clear look of logoless, but I wanted to make the car my own.
vadr45
Alexandria, VA
Old 05-28-2012, 10:46 PM   #14
TOLMACH
Drives: soarer
I tried dental floss today.. fucking yaris badge is much stronger .. badge won today ((
Old 05-28-2012, 10:49 PM   #15
LA Yaris
Yaris323
LA Yaris's Avatar
A blow dryer would work to heat up the glue.
Old 05-29-2012, 01:46 AM   #16
TOLMACH
Drives: soarer
^ thanks man
I found some polyethter threads from the craft store at my place and they did the job.
I also discovered some strange residue once removed the badge and double sided resin - had to use the rubbing compound to remove it.
Installed the TRD logo instead- looks so much better now.
Thanks again to everybody.
Old 05-29-2012, 04:21 PM   #17
mazilla
advocatus diaboli
mazilla's Avatar
Fishing line instead of dental floss, etc next time. A length of 20lb test works nicely...just wear some gloves, the little cuts you might get from the line are annoying.
-Type 07 FFL-
My odometer 03/11
Old 05-29-2012, 04:25 PM   #18
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
Use a debit/credit card instead. It is way easier. Just work it into one side under the emblem and keep at it. By far the easiest method, I have tried them all on all my prior cars. Just make sure its not a card you are going to need bc it will scratch and possibly crack.
HELP - Wire Speaker through Rear Door (Yaris) lAYJAY In Car Entertainment + Electronics (audio / video / alarm) 10 01-07-2013 09:01 AM
