Old 05-12-2012, 07:42 AM   #1
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
The biggest problem that the Yaris faces with top speed is frontal area. It's a tall car and even though it's egg-shaped, the total frontal surface of a body is a major factor in determining its top speed. Even if you got a bonkers overdrive ratio (like 0.6:1) for 5th gear, our 100 little bronies can't cope with the aero issues beyond a certain speed.
Here's a more in-depth evaluation of the ideas.
Old 05-13-2012, 07:37 PM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Originally Posted by CrankyOldMan View Post
The biggest problem that the Yaris faces with top speed is frontal area. 100 little bronies can't cope
I have the sedan so at least the tallness is not as drastic as the LB. Also, I left the stock HP/Torque in the rearview last summer and it is only going up from here. All of the information and food for thought you provide is appreciated and great to ponder over that is for sure.
Tags
c50, c56, c59, swap, transmission
Do I need a transmission flush at 57K miles if 07 Yaris should last until 100k? lejulie DIY / Maintenance / Service 14 10-23-2011 07:43 PM
Can non-Toyota dealers/repair shops replace transmission fluid w/o "special equipment lejulie DIY / Maintenance / Service 10 10-23-2011 07:35 PM
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 02:52 PM
Installing a external in line transmission filter. YarisSedan Performance Modifications 1 03-31-2009 08:03 PM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
