2ZR swap. DO IT! Ask how!
The biggest problem that the Yaris faces with top speed is frontal area. It's a tall car and even though it's egg-shaped, the total frontal surface of a body is a major factor in determining its top speed. Even if you got a bonkers overdrive ratio (like 0.6:1) for 5th gear, our 100 little bronies can't cope with the aero issues beyond a certain speed.
Here's a more in-depth evaluation of the ideas. Last edited by CrankyOldMan; 05-12-2012 at 08:04 AM. |
| Tags |
| c50, c56, c59, swap, transmission |
| Do I need a transmission flush at 57K miles if 07 Yaris should last until 100k? | lejulie | DIY / Maintenance / Service | 14 | 10-23-2011 07:43 PM |
| Can non-Toyota dealers/repair shops replace transmission fluid w/o "special equipment | lejulie | DIY / Maintenance / Service | 10 | 10-23-2011 07:35 PM |
| Problem help | MickZEL | DIY / Maintenance / Service | 38 | 08-01-2011 02:52 PM |
| Installing a external in line transmission filter. | YarisSedan | Performance Modifications | 1 | 03-31-2009 08:03 PM |
| Want opinions automatic vs. manual transmission | anik | New YARIS Purchase Forum | 84 | 07-10-2007 04:25 PM |
