Old 05-23-2012, 07:15 PM   #1
Boost Addicted
Drives: 2008 Yaris 5spd, 2005 GLI 1.8T
Parts source for A/C line/pressure switch!
Hey guys whats up?
So my girlfriends car is at it again... A/C is inop.
I used the Launch at work to scan the Climate Control Module and came up with one code and diagnostic tree to which I found the source of the problem... The A/C High/Low pressure cutoff switch.
I've called Advance Auto, NAPA, even Toyota, but nobody sells one. At this point I'm assuming the switch only comes WITH the high side A/C line?
So far I can't find anywhere that sells one, except Toyota, and they want $227 even with my 'technician discount'.
Is there a place I can buy just the sensor?
Is there a cheaper source for the line?? Does anyone know if the sensor even comes with the line?
Thanks guys
Boost Addicted is offline   Reply With Quote
Cruise control install 2009 Yaris 3 door PeteZNY DIY / Maintenance / Service 125 03-31-2024 09:22 AM
DIY - Headlights off with the Ignition Switch CTScott DIY / Maintenance / Service 46 11-03-2018 08:42 PM
Removal of the Factory Integrated Source sqcomp In Car Entertainment + Electronics (audio / video / alarm) 7 08-24-2010 12:44 AM
Anybody know of a good oem parts source???? KrystyonWayne Cosmetic Modifications (Exterior/Interior) 4 11-02-2008 05:00 PM
