#37 |
![]() ![]() Drives: toyota Join Date: Feb 2011
so i gotta remove the wiper arms when i remove the cowl??
#38 |
always toyin'
Yes but it's optional. See Page 5 for instructions: attachment
http://www.yarisworld.com/forums/showthread.php?t=15135 .
- Procrastinators of the world unite! ...tomorrow. ![]() My Garage.. 'Mild' Drop & Misc..2-DIN GPS/Navi..DIY:Rear Wiper Delay..Ramps/Roll-Ups..Rain Sensing Wipers / Auto-Headlamps |
#39 | |
![]() ![]() ![]() ![]() Drives: soarer Join Date: Feb 2011
Background: I plan swaping the stock shocks with blue Tokicos and retain the original springs Step 14 and Step 19 of the manual above (see the link in the message by ToyToronto) show NUTS being placed in something that looks like a garbage bin. Does this mean I need to buy new nuts (the original ones must not be reused) . Later in the manual nut number apprears as 90179-12145. Thanks P. |
#40 | |
Only Happy When it Rains
Colin Chapman disciple |
#41 | |
#42 |
#43 |
Maybe I will do this after all. I was flirting with not lowering the car, but putting better struts on the front...now, it may make sense to lower it since you have to remove the spring anyways. I am only concerned about rub.
#44 |
Interesting that they do not show preloading the front before fully tightening the struts as is recommended in most instructions that come with struts. Likely, if you are getting an alignment shortly after install, it doesn't matter...I guess.
#45 |
^ It's not necessary on the Yaris, if you look at how the top mounts work.
#46 |
Drives: Yaris Prius C2 Join Date: Mar 2013
Very good but one thing left out. They need to point out that the upper mounting nut is double. Removing the top nut is the removaql one to get the shock out. The shock assembly has a nut of its own. And it isn't necessary to remove the cover plastic or wipers.
#47 |
What is the last step (45) in that PDF?
#48 |
![]() ![]() ![]() ![]() ![]() Drives: Decepticon - Ravage Join Date: Nov 2008
You mean: Wheel alignment and Head light adjusting?
![]() Check out my Build thread: http://www.yarisworld.com/forums/showthread.php?t=52274 |
#49 |
![]() Drives: 2014 Yaris HB Join Date: Jul 2014
Not sure what I'm doing wrong but I'm struggling to remove the top nut with my offset wrench and hex key in place
#50 |
If I recall, that was one of the tougher nuts to remove. Have you tried using a cheater bar?
#51 |
The torque on that nut is only 55Nm. I couldn't get it with a regular box wrench, but an offset made it easy. Rotate it so the hex key is pressed up against something, then you can get the nut loose.
#52 | |
![]() Drives: Yaris 2010 Join Date: Apr 2015
Be careful with the front anti roll bar link. If the locknut is rusty it will probably strip the inside where the allen key fits. Also clean the bolts threads so it doesnt make it seize when you are using the wrench. |
#53 |
Good PDF for reference.
![]() I also like the video by KYB. Very understandable. https://www.youtube.com/watch?v=0FEIDAFDnTA&t=436s I will most probably change the shocks in a few weeks. The springs are not cracked. Can they be "tired" so that it would make sense to change them too despite the fact that they seem intact? My Yaris 2007 is still on the original shocks and springs and they are nearly gone according to the suspension diagnostic test. |
#54 |
To compress the springs you can easily get a compressor worth 10 bucks. It will do the job nicely, not as fast as a professional electric compressor but it is safe comparing to any other home-invented mean of compressing the coils. Compressed coil is a grenade ready to explode.
| DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 07:01 PM |
| DIY needed for amplifier for sedan install | YarisSedan | In Car Entertainment + Electronics (audio / video / alarm) | 2 | 02-27-2009 10:07 PM |
| TRD spring install pics | tristan | Photo-Video-Media Gallery | 10 | 02-20-2009 10:33 PM |
| Suspension install: Spring Compressors? | Thirty-Nine | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 15 | 09-18-2007 10:59 PM |
| TANABE DF210 Spring Install [pics] | Chris07LB | DIY / Maintenance / Service | 148 | 07-16-2007 09:26 PM |
