Old 06-05-2012, 11:42 AM   #4
packetrace
packetrace's Avatar
Drives: Yaris Sedan 2009
When I jump pin 3 in pin 4 it lights :D
So I tapped the Yellow/green wire to the pin 4 (lowbeam so it is like OEM)
I cut the wire on pin 3 and use the side of the wire that go to the relay...not the side that go to the oem stalk..AND solder it to the orange/red wire of the switch...
Everything works perfectly except one thing..
The switch light a little bit in permanence...which I can bypass by cutting the resistor of this light...
but when I pushed the switch and that the lowbeam are on...the fog lights....but there is no light on the switch which is bad...
But if the stalk is in parking light or off....the led of the switch lights a lot...like it would be supposed even on lowbeam..
WHat would be my problem ?
Should I have tapped the two parts of the pin 3 instead of just one side ?
Interior:ALL red, black roof
HID flickering problem - DRL fog - Problem solved. IllusionX Cosmetic Modifications (Exterior/Interior) 9 10-01-2009 06:37 PM
Sorry! Another fog light question. Jrilla DIY / Maintenance / Service 4 08-23-2009 02:25 PM
My Yaris Fog Light ezlove0710 DIY / Maintenance / Service 7 08-07-2009 06:15 PM
Fog Light Misalignment and Moisture DjT General Yaris / Vitz Discussion 3 04-27-2009 03:24 PM
Fog Light Help cm07yaris DIY / Maintenance / Service 30 03-28-2009 10:19 PM
