0-60 in slow
I'm running the trd bar and would probably go to a bigger bar if I could do it over.
To add to this I pulled my front bar off last weekend to get an idea of how the car behaved with it missing, and it wasn't doom and gloom like I expected plus my times were something in the range of 2 seconds faster on a 60 second course this is also with running -.8 camber vs the normal -2.7 I usually run. Going over my data I definitely lost lateral traction something like 0.05g but I was able to get on the gas so much earlier that the slight loss in lateral traction didn't matter. I wouldn't recommend this for anyone unless they were running much stiffer springs since body roll increased dramatically. Also I was having problems with rubbing as well as the car became quite a bit more loose and would oversteer on trail braking which is good for me Last edited by xnamerxx; 06-05-2012 at 04:10 PM. |
#2 | |
![]() ![]() ![]() Drives: 2010 Yaris HB Blazin' Blue Join Date: Feb 2011
racerb '86 Celica GT '87 Celica GT-S '98 Rav4L '01 Tundra SR5 |
| Got new TRD sway bar! | caineroad | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 11 | 08-24-2009 10:55 AM |
| Is the TRD rear sway bar a worthwhile upgrade? | YellowJolt | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 29 | 07-15-2009 08:07 AM |
| Does the TRD rear sway bar promote tire wear? | detroiter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 03-29-2009 10:29 AM |
| TRD Rear Sway Bar Install ?? | bikegerm | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 12-26-2008 01:46 AM |
| Installed TRD Strut + Sway bar | Blenjar | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 21 | 07-10-2007 11:46 PM |
