Old 07-21-2012, 10:04 PM   #1
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
Looks great! Are you going to bling it up with a polished fuel rail?
-Type 07 FFL-
My odometer 03/11
Old 07-21-2012, 10:11 PM   #2
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
I'm a linear one-step-at-a-time person, and only focus my attention on what needs to be done right now.
I'm still at #1.
1. Flange Fit.
2. Throttle Body Fit.
3. Weld.
4. Blast.
5. Clean.
6. Dyno.
Old 07-22-2012, 08:08 AM   #3
Billiam
Drives: '10 White Yaris 4D LB
1 million HP.
If you want to enjoy your car, stay off of the internet.
Old 07-22-2012, 12:42 PM   #4
tooter
play every day
tooter's Avatar
Originally Posted by Billiam View Post
1 million HP.
The 1 is a good guess.
Old 07-22-2012, 10:02 AM   #5
mazilla
advocatus diaboli
mazilla's Avatar
I'm still at #1.
1. Flange Fit.
3. Weld.
4. Blast.
5. Clean.
6. Dyno.
I get that, but I'd still put fuel rail in there somewhere so I didn't have to take all that stuff apart, maybe 5.5.
-Type 07 FFL-
My odometer 03/11
Old 07-22-2012, 12:14 PM   #6
tooter
play every day
tooter's Avatar
I'm not going to make any other changes while working on this manifold. They would only complicate the process which I want to be as simple and direct as possible.
It's really easy to get in way over your head by making multiple changes at the same time, so I'm going to completely avoid that situation simply by not doing it.
Old 07-22-2012, 10:35 AM   #7
5a. Drive
5b. Disconnect the battery to clear the CEL (after noting the error code)
5c. Repeat.
Just kidding, I am truly hoping those steps aren't included.
Old 07-22-2012, 11:47 AM   #8
tooter
play every day
tooter's Avatar
5a. Drive
5c. Repeat.
I have no idea... this is all new to me.
You know far more about that than I do since you have years of experience with your manifolds and are a lot farther along in the process than I am. They certainly have to have been test run by now. Have any of your own short or longer runner manifolds triggered check engine lights? And if they did, how did you address them?
One decided advantage is that the throttle body and engine on either side of my manifold are in exactly the same bone stock condition as with the OEM manifold.
So with the manifold itself as the only change I don't anticipate any issues. With no alteration of the size or profile of the actual entry and exit ports, utilizing all of the stock gasketing to insure a leak free design, and designing all of the adaptations to be smoothly transitioned, I'm optimistic that it will be just fine.
The check engine light issue would be greatly complicated if there were other concurrent changes being made. It would be much more difficult to address. This is why I'm focused just on making this one mod and nothing else.
Old 07-22-2012, 02:17 PM   #9
Changing one thing at a time is a great strategy. There have been many times I wish I followed it, both on my cars and in my life.
Old 07-22-2012, 03:21 PM   #10
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
That is an OK strategy for "almost stock" type builds.
If you go "full race" type build you gotta jump in with both feet.
Old 07-22-2012, 04:39 PM   #11
But after you do that build, it's still better to change one thing at a time, when possible, or you'll never know what change made the difference, either way.
Old 07-23-2012, 01:45 AM   #12
tooter
play every day
tooter's Avatar
Here's a pic of a gasket fit during the CNC of the throttle body adaptor...
These guys are artists!
Old 07-23-2012, 10:18 AM   #13
I like it.
Old 07-23-2012, 10:22 AM   #14
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
so.....time to head to the welder?
Be the change you wish to see in the world -Mahatma Gandhi-
BEEF is offline   Reply With Quote
Old 07-23-2012, 11:16 AM   #15
tooter
play every day
tooter's Avatar
No welder yet...
Today I go to the shop after work to return the flange that was hand filed to fit to the engine, so they can input the corrected dimension data and CNC another flange...
...then I go to the welder.
Old 07-23-2012, 12:01 PM   #16
vten
Project is looking good tooter !
Old 07-23-2012, 12:02 PM   #17
BEEF
BEEF's Avatar
so they are going to mill you out another flange? are you paying for every time you use them or is it one fee? you could just used the filed one.
sorry, being impatient. I like this little project. regrardless of the gains, it is going to look mighty mean on the front of that engine.
Old 07-23-2012, 12:28 PM   #18
tooter
play every day
tooter's Avatar
Originally Posted by BEEF View Post
...sorry, being impatient.
That's ok... as long as I'm patient the project will turn out just fine.
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
