Old 08-27-2012, 07:01 PM   #1
whew. I really can't show it til tomorrow.
Old 08-27-2012, 07:13 PM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
awww....turn that frown upside down
Tomorrow is only a couple thousand more minutes anyway.
Old 08-27-2012, 09:00 PM   #3
4/20 NEVER FORGET
Drives: 2008 Yaris HB MT
No rush. I'm excited to see it though!
4/20 NEVER FORGET is offline   Reply With Quote
Old 08-28-2012, 03:57 AM   #4
pics tomorrow guys -- I'm beat but I can't sleep. The manifold fits and the car runs. We had to get creative with hoses and such, but those details can be worked out later. The game is on!
Thank you Jeff for your patience and creative solutions.
Old 08-28-2012, 07:43 AM   #5
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
^ did you start your own thread on it yet?
Old 08-28-2012, 12:37 PM   #6
This was, and is, tooter's thread. Sorry to post up so much in here "off topic".
Here is a new thread for our manifold project:
http://www.yarisworld.com/forums/sho...854#post663854
Old 08-28-2012, 07:13 PM   #7
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
No problem, Garm.
We're on the same side.
Old 08-29-2012, 10:29 AM   #8
It would be a reverse step (if you can even call it that) if the flange is 1zz and a smaller 1nz throttle is mounted on it, and it's after the the throttle. That's how our test car is set up.
I don't know if that's going to make much of a difference.
Old 08-29-2012, 01:25 PM   #9
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Here's a pic of a 1ZZ TB from the manifold side. If you need/want a different angle or direct measurements, I can scare those up too. I bought one from fleaBay for $50 and ended up sacrificing it to the techno-god "Howzitwerk" to see if it could be disassembled, cleaned, and reassembled. Turns out the answer to that is a resounding NO.
Oh, and the .pdf is a measured drawing that I made of the basic dimensions. If the picture looks like it's mirrored from the drawing, it's because the right half of the drawing is the face of the manifold, not the TB.
Old 08-29-2012, 09:21 PM   #10
tooter
play every day
tooter's Avatar
Hey, thanks Cranky!
It looks like a simple straightforward change to make the adaptor 51mm to match the 1zz throttle bore. That will make three possible tooter options:
1NZ 4 bolt 48mm
1ZZ 4 bolt 51mm
1ZZ 3 bolt 51mm
Old 08-29-2012, 05:40 PM   #11
Jeff@MicroImage
"Know it all"
Jeff@MicroImage's Avatar
Drives: Lancia Delta Integrale
Tooter, we have a couple of 1ZZ throttle bodies available here if you want to pick one up.
www.microimageonline.com
Jeff@MicroImage is offline   Reply With Quote
Old 08-29-2012, 05:58 PM   #12
suckerface
#1 Lemming
suckerface's Avatar
Drives: Light Blue '08 Yaris
Just to clarify, they're the -030 parts, correct?
Old 08-29-2012, 06:00 PM   #13
packetrace
packetrace's Avatar
Drives: Yaris Sedan 2009
how much do you sell them ?
Interior:ALL red, black roof
Old 08-29-2012, 06:05 PM   #14
Jeff@MicroImage
"Know it all"
Yes
You can't have one.
Old 08-29-2012, 06:08 PM   #15
packetrace
packetrace's Avatar
You can't have one.
YGPM...
Old 08-29-2012, 09:15 PM   #16
tooter
play every day
tooter's Avatar
Thanks, Jeff. Cranky's pic did the job. I just wanted to see if the bore was equidistant from the 4 studs so that the adaptor bore diameter can be adjusted accordingly from tapering down to 48mm to straight 51mm.
Old 08-29-2012, 06:24 PM   #17
He has a dryyyyy sense of humor.... unless he meant it. LOL
Old 08-29-2012, 06:25 PM   #18
Jeff@MicroImage
"Know it all"
YGPM...
PM Replied and emailed you also.
I was joking
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
