Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
I would get a drimal and clean up that corrosion^ maybe smooth it out a little.
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
play every day
The black is just accumulated layers of unburnt hydrocarbons that repeatedly got cooked over the many years of the manifold's life. I'll be spraying the whole insides with engine degreaser and hosing it out. Can't get inside there with a Dremel. The hole is way too small and the runners are too deep inside the plenum.
play every day
Saw this pic of a thick custom made intake flange on the Micro forum...
![]() I tried tapping with ball peen hammer on the inside of the runner to flare the opening with some success. But instead of risking denting or deforming the runners, a thick flange like this one with a few extra beads of weld on the misaligned areas will provide plenty of room to smooth the transition from the inside with a grinder between the runners and the engine intakes. |
| homemade intake manifold | ttr125fan09 | Performance Modifications | 1 | 02-17-2012 01:09 AM |
| Custom Intake Manifold + Direct Port Nitrous | blacksandiegovitz | Performance Modifications | 9 | 04-21-2010 07:05 PM |
| Turbo Manifold thread | Sabretooth | Forced Induction Forum | 78 | 05-22-2009 06:52 AM |
| turbo manifold build... | joey1320 | Forced Induction Forum | 4 | 06-30-2007 02:26 PM |
