#19 |
![]() ![]() ![]() Drives: 2007 Liftback Join Date: Mar 2012
I just ordered the whole fan unit assembly from rock auto, here's to seeing if it's worth it. Includes fan, motor and entire shroud. Pretty much drop it in and plug it up.
#20 |
CT Scott;
Is the integration relay the one that has like 3 or 4 relays built into a rectangular black plastic piece? Do you have a pt # for the 2008 LB fitment? THX!
#21 |
Yes. It is the one that is part of the under hood fuse panel. Part number is: 82641-47020
#22 |
This? 35$ used. States its for an '07 Sequoia. Same P/N though...
#23 |
Yes. The same one is used in a boat load of Toyotas.
#24 |
~$90 and three days shipping later.....
![]() New fan, with motor, preassembled, ready to drop into my car. |
#25 |
Holy heck. Just figured out what CTScott was talking about with the 30A blown fuse. $4 later, the fuse is in.
Old fan works fine. |
#26 |
Part of me wants to rip the dealer a new one. Another part of me feels stupid for not figuring this out sooner.
#27 |
Only Happy When it Rains
the dealer should have known. There is a reason we take cars to mechanics. We can't possibly know everything.
Colin Chapman disciple |
#28 |
![]() ![]() Drives: 2009 yaris sedan Join Date: Apr 2011
can u return the fan assembly?
#29 |
![]() Drives: 2007 Meteorite Hatch Join Date: May 2011
Hi, 2o6. I recently found that my relay AND motor have gone bad. The relay is burnt (can be seen through the clear top of the pink relay) and the fan motor needs replacement, as well. I saw that you got the whole assembly for $90 according to your last post, but I can only find it online for around $300. Can I ask where you got the fan assembly?
#30 |
Always check the fuse first when theres an electrical problem...
Been there done that!
#31 | |
Ohm's law
#32 |
Wow never thought of ohming out the empty fuse socket.
![]() That shows what I know.
#33 |
ok, so 14 volts through a 30 amp fuse.
V = I * R 14v = 30A * R R = 14/30 = 0.46 Ohms. Is a bad fan likely to blow a fuse? I saw somewhere in this thread that both a bad fan and a blown fuse are unlikely, but it seems to me that a bad fan could blow a fuse.... Also, my mechanic wants to charge me $385 for parts and labor to replace the fan. But I know that the replacement wouldn't take me ah hour or so to do, and 2o6 mentioned that he got the parts online for $90. Does anyone know where I can find that? Can I get a junk fan? |
#34 |
A fan can fail as an open or short. A short will blow the fuse. It can also fail mechanically where it binds and draws enough current to blow it. I had broken fan blades on crashy2 and picked up a fan from a junkyard for $40.
#35 |
El Huevo
Drives: 2007 Liftback Join Date: Aug 2006
Just had this same thing happen to my yaris, the fan was working here and there and finally died, I initially thought the a/c needed a recharge, then i got the temp light and it turned out to be the fan. I was able to get a new fan assembly for a little under $90 shipped from amazon. Installation was a breeze!
#36 |
| Coolant Light | Betrthanren | DIY / Maintenance / Service | 8 | 01-21-2013 11:11 AM |
| How many forum posters does it take to change a light bulb? | silver_echo | Off-topic / Other Cars / Everything else Discussions | 25 | 06-27-2011 01:50 AM |
| Flashing Third Brake Light with DIY | bobolinko | DIY / Maintenance / Service | 33 | 05-23-2011 06:14 PM |
| LED'n it out (warning...big pics) | custom Lftback | Photo-Video-Media Gallery | 9 | 05-24-2010 03:41 AM |
| Coolant Light | Cathy | DIY / Maintenance / Service | 15 | 09-04-2006 12:28 AM |
