Old 06-08-2012, 10:22 PM   #1
2o6
Drives: 2007 Liftback
flashing coolant light
Drove my car to work today, noticed the flashing red light literally as I pulled up to my job. Popped the hood, no signs of failed water pump (no coolant everywhere, no boiling coolant, car running/idling fine) I had the A/C running, too. I just recently noticed the crapola accessory belts and a slight odd whine (may be the crap belts)
I did a quick idle test, (let it idle for around 10 minutes) and I noticed the fan never came on....
Worst case scenario - water pump, (a known issue on these cars) but I think it may be the coolant temp sensor.
2o6 is offline   Reply With Quote
Old 06-08-2012, 10:44 PM   #2
Do you see the green "cool" light when you start it and see the light goes out after a couple of minutes of driving?
For the light to flash, the ECM would have to see the sensor indicate that the coolant is 242 F or more.
Old 06-08-2012, 10:52 PM   #3
2o6
Yep, engine cold light goes out/comes on normally. I drove the car to work (had let the car rest for 40 minutes) and the car was fine until literally I got to the parking lot of my job. Coolant light flashed red. I stopped, and checked under the hood (around 2-3 minutes passed) nothing to suggest otherwise. No pink coolant under the hood, no coolant everywhere no boiling coolant.
I'm thinking faulty sensor; I let the car idle for 10 minutes (had already been warmed up from the drive home from work) and I never heard the fan kick on. I figure the car would be ready to blow for the light to come on like that. But no symptoms that supports that.
I'm taking it to the Toyota dealer tomorrow and seeing what they say.
Old 06-08-2012, 10:57 PM   #4
2o6
Would a malfunctioning rad fan (coupled with A/C on) cause this to happen?
Old 06-08-2012, 11:21 PM   #5
It could, as could a stuck thermostat or plugged radiator.
Was the fan running when you pulled into the lot, or did you kill the engine before you got out and popped the hood?
Old 06-08-2012, 11:41 PM   #6
2o6
Fan was not running, IIRC.
Old 06-09-2012, 08:58 AM   #7
Was the fan not running with the A/C on either? The fan should run continuously while the A/C pump is running.
Old 06-09-2012, 09:49 AM   #8
2o6
Got it back from the Toyota dealer
Fan relay and motor died.
Cost of replacement? Nearly $1000.
Screw that, I'm going to an indie shop.
Old 06-09-2012, 09:54 AM   #9
2o6
Anyone know the part numbers and such for this? The dealer's charge seems just too high for me to pay.
EDIT
Quick search shows I can get a NEW fan w/motor and fan relay for around $100 combined.
What the heck? How does the dealer get off on charging that price?
Old 06-09-2012, 11:57 AM   #10
less people want to buy parts from dealers, so...
dealers jack up the profit margin to compensate, so...
less people want to buy parts from dealers, so....
ad infinitum...
Old 06-09-2012, 12:24 PM   #11
2o6
If the fan isn't turning because the motor is out, why would they be charging me for the shroud, blades, bearing, when the part online is already assembled and pretty much only the motor is broke?
Old 06-09-2012, 01:59 PM   #12
pennyracer
boydstir
pennyracer's Avatar
Drives: 08 yaris liftback
Send a message via AIM to pennyracer Send a message via Yahoo to pennyracer
because they are changing the hole unit as one instead of just replacing the motor only not sure if you can even buy the motor by itself
pennyracer is offline   Reply With Quote
Old 06-09-2012, 02:03 PM   #13
pennyracer
boydstir
pennyracer's Avatar
is you coolant level up all the way and the overflow box included
Old 06-09-2012, 02:04 PM   #14
I have a feeling that they didn't troubleshoot it and just pulled a number out of the air. The chances of both the relay being bad and the fan being bad is pretty slim.
I would start with checking out the 30A RDI fuse in the under hood fuse panel.
From there, there are actually two relays for the fan. One is the primary switching relay (FAN NO.1 Relay) and the second (FAN NO. 2 Relay) switches the speed of the fan by switching in a huge resistor.
If you have a multimeter (or a friend who does) it is very easy to test out the relays.
Old 06-09-2012, 03:02 PM   #15
2o6
The relay is fine, the motor is burnt out (confirmed). Rock auto shows that the entire fan is around $70-120 fully assembled, motor included.
Here is their rundown:
32 Amp $17.46
Cooling fan $ 52.60
Cooling fan Relay $ 82.51 (it's actually only $30)
Shroud $118.21
Fan $101.33
Motor $206.90
Nut $ 14.46
Labor - $360.67
$954.35....plus tax.
I called my shop, they're at around $100 labor, but I would need to supply the part. Ordering it through the dealer only comes piece by piece. I'm either going to rockauto it, or junkyard it.
Old 06-09-2012, 03:12 PM   #16
There are two relays. The Fan Relay No. 1 is part of the integration relay, which is about $80 from a dealer. The Fan Relay No. 2 is the $30 dealer one.
Out of curiosity, how did you confirm the burnt out fan motor?
Old 06-09-2012, 03:55 PM   #17
2o6
They used the diagnostic tool to confirm that the fan motor is burnt out. Then there is a lot of drag on the blades itself.
Old 06-09-2012, 04:09 PM   #18
OK. I was just curious, as I've seen a couple of bad integration relays on Yaris, but never yet a bad fan motor.
Coolant Light Betrthanren DIY / Maintenance / Service 8 01-21-2013 11:11 AM
Flashing Third Brake Light with DIY bobolinko DIY / Maintenance / Service 33 05-23-2011 06:14 PM
LED'n it out (warning...big pics) custom Lftback Photo-Video-Media Gallery 9 05-24-2010 03:41 AM
Coolant Light Cathy DIY / Maintenance / Service 15 09-04-2006 12:28 AM
