Old 06-12-2012, 06:30 AM   #1
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Doh, I should have been more specific, eh? The bolt pattern for the head-side of the intake. I made some educated guesses on my CAD model, but haven't actually measured them.
Old 06-12-2012, 11:15 AM   #2
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
You got it.
When I get home from work this evening, I'll lay straight edges across the two rows of bolt holes and will be able to give you some x and y measurements.
Old 06-13-2012, 12:37 AM   #3
tooter
play every day
tooter's Avatar
Hey Cranky,
Here's some of the measurements. They're not perfect but accurate to a millimeter because I just used a ruler.
Bolt holes on intake manifold to engine head connection
looking at the flange from the position of the bolt holes making a W.
The y distance between the two rows of bolt holes (not including the one hole that's offset) is 24mm.
The x distance between the two holes on either side of the center hole is 166mm.
The x distance from the center hole to the end hole which is in line with it is 163mm.
The y distance beween the one offset hole and the closest hole to it is 33mm.
The x distance between the center hole and the offset hole is 163mm.
Hope this helps. Let me know if you need any clarification.
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
