kinda hope the group buy won't be for a while since I won't have that kind of money until a (long) while.
やりすぎだ~
Think of the airbag as an accordion-style balloon with really thick walls. The "balloon" is attached at the top and bottom perches where the spring would normally sit. Put air into it and the bag expands vertically. Remove air from it and it compresses. Since the air in the bag doesn't escape on its own, your car will always remain at the same ride height depending on amount of air inside. As for going over bumps, you do not need to refill them because the air inside the bag does not go anywhere when the bag compresses over bumps. Like a balloon, the airbag will expand outward slightly under compression, but return to its normal state after going over the bump.
@CTScott - I could measure it this weekend if you want. What part do you want me to measure? |
#3 | |
Form>Function
Drives: 07 Flint Sedan Join Date: Dec 2009
I see perfect thanks.
I was aware of their shape and how they sat in the unit thats why I was unsure of how they react to bumps. It would be brutal if you filled them and they sat like big rocks and didnt move lol. Thats pretty cushy I imagine must be nice for a daily. Under extreme pressure can the bags rupture? Assuming you would probably have to do Dukes of Hazard stunts to put that much pressure on them lol |
やりすぎだ~
Rupture? Definitely.
That's why a warning is given for any bag install - NEVER drive when bag is maxed out or when bag has no air at all. Airbag like virginity, one prick all gone. |
Form>Function
Wow thats good to know what about debris? Can it gouge/pop bags?
やりすぎだ~
Well, actually the wall of the bag is pretty tough and able to withstand any road debris. You would have to deliberately puncture it to make a hole.
@CTScott - I'll see what I can do. |
Form>Function
Good info. Thanks
![]() ![]() Drives: white yaris hatchback. Join Date: May 2011
sorry havent been checking much the past few days. been busy
my kit has a beveled rear bag (like posted above) and the fronts have a slimmer sleeve like bag. like the bag on the front strurts seen on this scion kit http://bagriders.com/modlab/products...ANAGEMENT.html as far as bag material: like already said its pretty heavy duty, much like the bags you would see on semi trucks or city buses. only they are much smaller, and those bags go for 100's of thousands of miles normally without problems. i really feel like that if i ever have a leak in my system it wont be from one of the bags. *knock on wood* @CTScott: for my max ride height the fronts probably put the car at the same height it was on Micro Image springs. the rear when maxed out probably has almost 2 feet of lift above the wheel haha. but like has been said it is NOT suggested to drive around for long periods of time with the bags maxed out. the ride is VERY VERY hard and could cause ruptured bags. thanks yarisugi for chiming in also with his bagged knowledge and experience. thanks for answering the question about how the bags act as the springs. http://www.facebook.com/events/409623035736058/ i will be at this event in the cleveland, OH area. if anyone wants to check it out in person Last edited by DINOeggxo; 09-08-2012 at 05:13 PM. Reason: adding link |
やりすぎだ~
@CTScott - Sorry, I couldn't measure from strut bolt to tower. Why? Because the
aigbags are filled with air, blocking my tape measure. So I measure it another way. I measured vertically from hub center to fender edge. I suppose this would be a good reference point regardless of tire/wheel size. Front measured 16 inches and rear was 17-1/2 inches. Hope this helps. The picture is of the suspension at its highest point. |
^ Actually that is perfect. I am trying to figure out for Crashy 2 if I can use airbags to allow me to transition between plowing height and driving height.
Toyota
Drives: '11 5dr/5spd yaris Join Date: Nov 2009
oh wow, it's nice to see this stickied.
![]() ![]() ![]() ![]() ![]() Drives: red bare bone yaris hb 3dr Join Date: May 2009
im torn between getting this airride kit or do an upgrade to a better coilover set :P
#14 | |
![]() ![]() Drives: 04.:R32, 87 Scirocco, 07 yaris Join Date: Apr 2009
The adjustability and looks when slammed is awesome. I love dinoeggs car, driving it is real fun too. |
#15 |
Yeah ... I'm liking the idea that you can slam the car all the way down when parking :)
Any update on the price Sasquatch ? |
#16 | |
The problem is that the manufacturer that made dinoeggs doesn't really want to sell Just struts as they make some kits too. But the rest of the kit is expensive and kinda crappy for how much you pay. So our dealer is tryin to get them to sell just the struts because he would be able to supply a wider variety of management options amd make a better kit for less money and be able to give you great after sale customer service if needed. I'm either case the struts will likely remain as "built to order" because most companies see no market in the yaris scene. He'll air lift is one of the largest companies in the game and they don't even make mk1 VW front struts for the same reason. Hopefully we will hear soon |
#17 |
war machine
Drives: 2012 yaris LE Join Date: Apr 2012
I would be down for a group buy
#18 |
Form>Function
Drive it like you park it.
| DIY Cabin Air Filter | BailOut | DIY / Maintenance / Service | 105 | 06-20-2019 12:59 PM |
| DIY - Cabin air filter location (Belta, Vios, Yaris sedan) | Murtaza_murti | DIY / Maintenance / Service | 5 | 04-05-2012 11:03 AM |
| Tata Motors to introduce Air Car - Is it the next big thing? | *MAD DOG* | Off-topic / Other Cars / Everything else Discussions | 24 | 09-29-2010 11:42 AM |
| Autoloc Air Bag Suspension System | Malaya1221 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 9 | 04-24-2009 10:53 AM |
| $7 Ram air intake pictorial | turbodiesel | Performance Modifications | 19 | 10-27-2008 05:46 PM |
