Old 09-06-2012, 05:02 PM   #11
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Think of the airbag as an accordion-style balloon with really thick walls. The "balloon" is attached at the top and bottom perches where the spring would normally sit. Put air into it and the bag expands vertically. Remove air from it and it compresses. Since the air in the bag doesn't escape on its own, your car will always remain at the same ride height depending on amount of air inside. As for going over bumps, you do not need to refill them because the air inside the bag does not go anywhere when the bag compresses over bumps. Like a balloon, the airbag will expand outward slightly under compression, but return to its normal state after going over the bump.
@CTScott - I could measure it this weekend if you want. What part do you want me to measure?
DIY Cabin Air Filter BailOut DIY / Maintenance / Service 105 06-20-2019 12:59 PM
DIY - Cabin air filter location (Belta, Vios, Yaris sedan) Murtaza_murti DIY / Maintenance / Service 5 04-05-2012 11:03 AM
Tata Motors to introduce Air Car - Is it the next big thing? *MAD DOG* Off-topic / Other Cars / Everything else Discussions 24 09-29-2010 11:42 AM
Autoloc Air Bag Suspension System Malaya1221 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 04-24-2009 10:53 AM
$7 Ram air intake pictorial turbodiesel Performance Modifications 19 10-27-2008 05:46 PM
