Old 06-15-2012, 09:25 PM   #1
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
question is "will it still be low when it is all said and done?" I don't know what the fab and flange are going to run but if it does some magic and adds ponies for lass than 250 i'm in for one once Micro Image gets the specs and make me one in red ;)
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood
Old 06-15-2012, 10:00 PM   #2
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
I can tell you that mine is costing a prohibitive amount of money. Also, I honestly don't how this is all going to shake out because I have no idea if it will actually make any real world power improvements over the stock manifold.
And remember...
Toyota holds the decisive edge with the latest cutting edge technology computer modelling and the unlimited ability of plastic to be injection molded into any conceivable shape.
I'm just recycling a 14 year old junk yard part.
So my only edge is that it was designed to flow for engine that's 20% larger than the 1NZ-FE.
Old 06-16-2012, 05:12 PM   #3
tooter
play every day
tooter's Avatar
Been nosing around the internet and found the very strange Prius manifold that also fits the Yaris engine...
It was designed to operate optimally within a very narrow range between 2,180 to 2,470 rpm.
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
