toyota
thanks scott.. what other issues would i ran into by jumping..beside low coolant level which can damage compressor...i wish they sell just the pressure switch rather than the whole pipes which includes high and low pressure switch.. over $500 bucks
If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit!!!!!! "Horsepower is how fast you hit the object. Torque is how far you move that object.." |
#2 | |
It is a shame on not being able to buy the sensor separate. The part number on the other thread is correct, but you can't actually seem to order them anyplace. The other option would be to pick up the line or sensor at a junkyard.
| DIY A/C low pressure line insulation | syntax | Middle East | 291 | 06-17-2021 02:05 AM |
| Low Tire Pressure Sensor | DebbyM46227 | General Yaris / Vitz Discussion | 24 | 10-18-2010 10:02 AM |
| Intermittent low oil pressure light. | Inspector14 | DIY / Maintenance / Service | 23 | 03-29-2010 01:46 PM |
| screw more psi in the tires. | thebarber | Fuel Economy Forum | 43 | 05-04-2009 04:46 PM |
