Old 06-26-2012, 11:47 AM   #1
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
It is a single pressure transducer that feeds the pressure reading to the AC ECU, which then decides if it is low, high, or just right.
so ur saying by jumping the low pressure switch harness thats automatically jumping the high pressure as well?? men this is getting too complicated.. appreciate the input though..
If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit!!!!!!
"Horsepower is how fast you hit the object. Torque is how far you move that object.."
Old 06-26-2012, 11:56 AM   #2
There is just one sensor (not a switch or switches, but a device that changes resistance based on pressure). That is why the two resistors, rather than jumpers are required to bypass it.
DIY A/C low pressure line insulation syntax Middle East 291 06-17-2021 02:05 AM
Low Tire Pressure Sensor DebbyM46227 General Yaris / Vitz Discussion 24 10-18-2010 10:02 AM
Intermittent low oil pressure light. Inspector14 DIY / Maintenance / Service 23 03-29-2010 01:46 PM
screw more psi in the tires. thebarber Fuel Economy Forum 43 05-04-2009 04:46 PM
