#199 |
Not quite a noob
I just wrapped mine. What I thought was a 1 man, 5 minute job tuned into a 2 man, 15 minute job. I used 1/2 in. wrap instead, it fit nicely when it was straight, but at the bends it was a pain. Some of the bends aren't fully wrapped, I couldn't get it all the way around. C'est le vie.
EDIT: And yes, JUST in time for summer! |
#200 |
![]() ![]() Drives: 07 lb jeep tj Join Date: Oct 2010
Am I the only one who thinks the yaris a/c works very well even down here the florida humidity?
#201 |
![]() ![]() ![]() Drives: 09 Meteoric Metallic 3 door HB Join Date: Jul 2010
Hey guys, I just bought the stuff to do this with.
I got the insulation and the zip-ties, and now I need to get the tape to reflect the heat. I've got a few concerns though... What if moisture gets under the insulation? The pipe won't rust will it? I'm rather worried about the long-term affects. I'll give it a whirl anyway seeing as how nobody has said anything bad about it.
#202 |
![]() ![]() Drives: 2008 yaris hb Join Date: Mar 2011
ss Zip ties
I put the insulation on with ss "zip ties" you can get them at harbor freight
#203 |
![]() ![]() Drives: 2007 Yaris Join Date: Jan 2012
i tried it and it melted , it's a fire hazard from my point of view even with reflecting tape,
if the car burns the insurance won't cover the only solution would be exhaust insulating fabric |
#204 |
Is this true? I can't see how insulating a line would actually affect the load of the compressor. It should simply be reducing the lost cooling in the pipes.
#205 |
![]() ![]() ![]() Drives: 2008 Yaris LB Join Date: Dec 2008
#206 | |
http://www.thesolarshop.eu/acatalog/...nsulation.html |
#207 | |
Probably less likely in ridiculously hot/arid places where the evaporator will deal with it. But in humid areas, or more sane temperatures, you may run into this. Cheers. |
#208 | |
![]() Drives: 2010 Yaris LB Join Date: Jan 2011
The accumulator is there to prevent any liquid from reentering the compressor, but I guess we'll wait and see if there are a lot of A/C failures reported in the future :) |
#209 | |
As I said, I am not certain that you would end up w/ liquid. It's certainly possible, and hearing that guys are noticing more load on the engine makes it seem more probable. ![]() Cheers. |
#210 | |
So, I don't see how adding a bit of insulation to simulate lower ambient temps will be detrimental. |
#211 | |
Oh yeah! I hated that "feature" and was happy to disable it :)
#212 |
![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
I've had mine insulated for 3 years or something now, and left it on during cold season, and have never restricted my use of A/C when cold outside. No problems at all, and the high temperature resistant tape holds up nicely.
#213 |
So now that some time has passed since it's first been tried, what I'm taking from this is that there don't seem to be any long term negative effects. Correct?
#214 |
I'm at 2 or 3 years, and no problems here.
#215 |
![]() ![]() ![]() Drives: 2008 Yaris LB Join Date: Apr 2009
For those of you who first did this mod in 2009, how's it holding up? Any negative effects on the AC system? Foam melting?
#216 |
Not quite a noob
I did this a year or two ago. The insulation right above the exhaust manifold has melted slightly, otherwise it's help up fine. Didn't REALLY notice a big difference though, but every little bit counts!
| A/C Not Blowing Cold Air...among other things | yarisitis | DIY / Maintenance / Service | 38 | 07-28-2016 04:00 PM |
| DIY (08' USDM LB): Interior Light Color Change | revnull | DIY / Maintenance / Service | 37 | 05-21-2016 12:59 PM |
| DIY Change Your Interior Light Grey Panels to Black | KCALB SIRAY | DIY / Maintenance / Service | 64 | 01-22-2015 01:25 PM |
| DIY: Unlink A/C from Defroster | stran | DIY / Maintenance / Service | 46 | 01-19-2015 09:17 PM |
| DIY Sound Insulation Guide? | qwerty123321 | DIY / Maintenance / Service | 4 | 02-07-2009 02:56 AM |
