Old 06-30-2012, 09:02 PM   #1
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Some pics with the air filter removed...
You can see how close the throttle body and MAF sensor are to the stack.
And heres a video of the engine running...
http://www.youtube.com/watch?v=JQt2uJ7PYfQ
There's not much intake noise even with the camera stuck up close. In the beginning the ECU was fishing around for an idle mixture trying to adjust to the open intake, but found its equilibrium by the end of the video.
Old 07-02-2012, 02:27 PM   #2
Intake noise is really only apparent at WOT under load. Sitting still at idle generates nothing. Sitting still and punching the throttle only produces a brief sucking sound. Out on the road, WOT is what makes them growl, which btw, cannot be heard with anything but the oem exhaust installed.
Old 07-02-2012, 04:42 PM   #3
tooter
play every day
tooter's Avatar
Yes, I found that out when I did some flat out runs on the freeway last week, in preparation for the dyno tune. Could hear a slight roaring sound over the exhaust at wide open throttle.
In normal driving it's just as quiet as the stock air box... which makes the little lady happy.
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
