Old 06-30-2012, 11:17 PM   #1
Originally Posted by biotope View Post
The chinese text mentioned means:
1. Green is to connect to left and right headlights (never mention whether is low or high beam)
2. Blue is to connect to the license plate light, left and right side light (not sure which lights they referring to) and display light. Question - is there any wire to tap for these lights signal?
Since it is for automatic on of the lights, I would say that green then goes to low beams.
For the blue, that would go to the green wire on the bottom right of your picture. Those lights are switched on the positive side, rather than negative like the headlights.
So, you will have to add a relay where the blue wire switches the ground side of the coil (and the positive side of the coil is connected to your ACC power wire). Then the normally open contacts will connect to the green wire on the headlight switch connector and to the green/white wire, which is the second to last wire on the opposite side of the bottom of the connector.
Old 07-01-2012, 07:28 AM   #2
biotope
Drives: VIOS (FL, 06 model)
What is the function of green/white wire? Do you have the entire headlight switch connector layout?
biotope is offline   Reply With Quote
Old 07-01-2012, 10:40 AM   #3
The green/white feeds the tail lights, license plate light, and front corner lights that come on when you turn the headlight switch to the first click (often called parking lights here in the US).
Attached are the illumination and headlight EWDs.
Vios - Headlight.pdf
Vios - Illumination.pdf
Old 07-01-2012, 09:01 PM   #4
biotope
Attachment 47507
Attachment 47508
Thanks, have a better visualization on how the switching system works.
Tried to draw up something for the relay connection, is my understanding correct?
Old 07-01-2012, 09:13 PM   #5
Correct
Old 07-08-2012, 02:26 AM   #6
biotope
Correct
Finally managed to spare time trying out the installation. Some issue encountered, not sure if you could advice?
Without the relay connection for the parking lights, everything works well. It could auto on the headlight in the dark and off the headlight in the bright.
But when I made the relay connection, it will auto on the headlight & parking lights in the dark but fails to off the headlight & parking in the bright. I could hear the relay switching sound but the headlight & parking lights remain on.
Tried to change another relay, still having the same issue. Any idea what goes wrong?
Old 07-26-2012, 10:25 PM   #7
biotope
Still cannot figure out why the parking lights cannot turn on by the autolight sensor. Maybe the output from autolight sensor for the parking lights portion is faulty.
Thinking of making some changes to the circuit by using the autolight sensor for the headlight portion. Below is the layout, not sure if this connection feasible? Any views?
DIY Projector/HID (sedan) Brian DIY / Maintenance / Service 145 02-05-2012 04:13 AM
Silverstar Ultra 9003/HB2 vs OEM headlight bulb comparison CTScott DIY / Maintenance / Service 54 02-14-2011 08:58 AM
How To Smoked Sedan Headlight -DIY zulhizainL902S DIY / Maintenance / Service 26 01-14-2011 02:12 AM
Glassylite Headlight Restoration Kit TEHxFALLEN V1.2 Photo-Video-Media Gallery 1 07-03-2010 12:51 AM
HELP! I detailed my interior, and now having a headlight issue! Astroman DIY / Maintenance / Service 4 06-08-2010 06:51 PM
