#1 | |
For the blue, that would go to the green wire on the bottom right of your picture. Those lights are switched on the positive side, rather than negative like the headlights. So, you will have to add a relay where the blue wire switches the ground side of the coil (and the positive side of the coil is connected to your ACC power wire). Then the normally open contacts will connect to the green wire on the headlight switch connector and to the green/white wire, which is the second to last wire on the opposite side of the bottom of the connector.
#2 | |
![]() Drives: VIOS (FL, 06 model) Join Date: May 2012
#3 | |
Attached are the illumination and headlight EWDs. Vios - Headlight.pdf Vios - Illumination.pdf
#4 | |
Tried to draw up something for the relay connection, is my understanding correct?
Correct
Finally managed to spare time trying out the installation. Some issue encountered, not sure if you could advice?
Without the relay connection for the parking lights, everything works well. It could auto on the headlight in the dark and off the headlight in the bright. But when I made the relay connection, it will auto on the headlight & parking lights in the dark but fails to off the headlight & parking in the bright. I could hear the relay switching sound but the headlight & parking lights remain on. Tried to change another relay, still having the same issue. Any idea what goes wrong?
#7 | |
Thinking of making some changes to the circuit by using the autolight sensor for the headlight portion. Below is the layout, not sure if this connection feasible? Any views?
| DIY Projector/HID (sedan) | Brian | DIY / Maintenance / Service | 145 | 02-05-2012 05:13 AM |
| Silverstar Ultra 9003/HB2 vs OEM headlight bulb comparison | CTScott | DIY / Maintenance / Service | 54 | 02-14-2011 09:58 AM |
| How To Smoked Sedan Headlight -DIY | zulhizainL902S | DIY / Maintenance / Service | 26 | 01-14-2011 03:12 AM |
| Glassylite Headlight Restoration Kit | TEHxFALLEN V1.2 | Photo-Video-Media Gallery | 1 | 07-03-2010 01:51 AM |
| HELP! I detailed my interior, and now having a headlight issue! | Astroman | DIY / Maintenance / Service | 4 | 06-08-2010 07:51 PM |
