Old 07-03-2012, 06:06 PM   #1
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Ive been running a ram air duct into my air box with the opening in the foglight hole. Ive ran 3 tanks this way with no noticeable difference in mpg. Highway power maybe feels better?
Im thinking ill make my own proper CAI using the blox...i really like that and i think i can squeeze it in the bumper...i got hammers...
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 07-03-2012, 06:38 PM   #2
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
I got hammers...
I was checking around on ebay and it appears that BLOX also makes a much smaller 4 inch diameter velocity stack filter...
You can tell the smaller filter diameter because it has almost no taper as compared to the 7.5 inch filter, but yet has the same black plastic end cap. The only unknown is the inlet diameter, but that could be determined simply by asking the seller. One negative... it's pricey at $77 including shipping.
edit: from checking around, that may actually be a 4 inch inlet filter and not useable on the Yaris. The seller could confirm whether the filter itself is 4 inch diameter, or the inlet is 4 inch diameter.
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
