Old 07-03-2012, 07:41 PM   #1
muffin_top
Drives: 2012 Yaris SE 5MT
The fender liners are substantially different between RS and L/LE. Mainly the shape of the front and the attachment points.
You will need the following:
Bumper Cover
Fog Lamps L+R
Fender Liners L+R
Upper Grille
Lower Grille
Fog Lamp Garnish L+R
Tow hook cover
All the hardware is the same, as well as the Toyota crest and reinforcements.
Sadly, this will not be cheap or easy.. :(
muffin_top is offline   Reply With Quote
Old 07-03-2012, 08:41 PM   #2
Lady J
Drives: Efficient
Thats what I was afraid of I knew about everthing else but was unsure,it is a lot to spend considering
Lady J is offline   Reply With Quote
Old 07-03-2012, 09:59 PM   #3
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
Bumper Cover
Fog Lamps L+R
Fender Liners L+R
Upper Grille
Lower Grille
Tow hook cover
Could you explain with pictures HOW different it is between the RS and LE, possibly?
Because i have 2009 on my 2007. And the USDM bumpers were more bubbly than the JDM ones. JDM were flatter. For the 2012, the bumpers seem to have the same curvature for the USDM and JDM. Should be a direct swap...and like i said, might have to use a ziptie to bend and tuck the fender liner to line up with the hole/s.
Bumper swap is easier than changing the oil on the car or replacing headlight bulbs...mounting the US plates is also easier for 2012 owners than 2006-2011 owners, since JDM rear bumpers have a gap in the license plate mount area.
Expensive...maybe, depending on who or where you get it from.
Radio swap from 2012 LE/SE into a 'L' richard_rsp In Car Entertainment + Electronics (audio / video / alarm) 28 02-18-2014 11:20 AM
DIY: 2012 Front Bumper Removal vrwm Third Gen Yaris General Discussion 15 07-19-2013 05:23 AM
2012 Bumper Removal carolinablue Third Gen Yaris General Discussion 5 04-01-2012 07:25 AM
First Drive: 2012 Ford Focus Kal-El Off-topic / Other Cars / Everything else Discussions 18 02-25-2011 05:41 PM
