#1 |
![]() Drives: 2012 Super White Yaris SE Join Date: Nov 2011
DIY: 2012 Front Bumper Removal
1st step in a couple of DIY's I have being written up.
All you need is a 10mm socket and ratchet and a flat head screw driver. Pop Hood and Remove front clips(7 clips)(By the Yellow Dots) ![]() Remove Clips using flat head screw driver or other pry tool to pull up on center piece, then pull the whole clip out. ![]() Remove Bottom bumper screws and bolts. 10mm socket and ratchet used.(by the yellow dots aproximately) Sorry for the bad picture. I'll get a better one when I do my break in oil change. ![]() Now bumper should be loose, on both wheel wells there are retaining nubs. Pull back on the bumper a little by the yellow dot and it should break free. ![]() Now pull the bumper off, there are more retaining nubs under both head lights. There are no more screws or bolts. Just give it a gentle tug and it will come off. If you have an SE Remove foglight bulbs, or just loosen the connector. It will be the last thing connected to the bumper. ![]() TADA!!
Nice DIY for the 2012 model, good pictures
Looks like it's slightly different that the earlier models. Is the hood seal across the top of the bumper cover a factory item or did you add that? Last edited by Stove; 11-21-2011 at 12:02 AM. |
#3 |
That hood seal is a factory item. One thing I noticed when looking at it a couple of weeks ago.
#4 |
Nice DIY!
#5 |
Gotta ask what it is you are doing which requires bumper removal so early in ownership.
#6 |
Piaa Sports horns and HID fogs.
Couldn't deal with the Meep Meep!!! I wanted HONK!!! lol
#7 |
Awesome!
Drives: 12 Yaris/07 yaris Join Date: Dec 2010
no hella supertones? have them on the echo, yay for 118db!
#8 |
TRIM HUNTER
Drives: 2007 BLAZIN BLUE YARIS 3 DR Join Date: May 2006
ordered one from toyota BUT ETA is 2/23/2012 and it was ordered back in NOV.
http://rocklandtoyota.com/IFrame.aspx?iFrameID=2388 TOYOTA PARTS AT A DISCOUNT........ |
#9 |
![]() ![]() ![]() Drives: Yaris SR '12 Join Date: Jan 2013
I know this is a pretty old thread but great DIY, thanks for posting. Just what I was looking for as I'm thinking of doing the same as you and fitting HID fogs :) you got any photos of them installed??
#10 |
Asshole
Drives: 2012 and 2013! Join Date: Aug 2012
One add to this, you dont need to remove the whole bumper. Just the top.
The bumper will pivot down. I installed fog lights, and PIAA horns without removing the bumper completely.
Cheapest DD I could find!! |
#11 |
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
are the horns plug and play?
MicroImageonline forums - Shroomster Xda Forums - Shroomster Androidforums - Shroomster I'm noticing a pattern...... Last edited by Shroomster; 03-23-2013 at 02:58 PM. |
#12 |
Asshole
If you see the picture in the OP, there are 3 holes on the top of the crash bar, use the outer holes.
Using 2 body bolts, and 2 "U" spring nuts on the holes. Some bolt it to the upper radiator support, where they can be seen through the grill. Mine are below the grill. The wiring needs to be extended by using a female spade connector (to the existing loom) crimped to two wires, splitting to one male spade connector to each horn. The existing horn fuse and relay handle it. I used the higher toned ones, they come as a pair: http://www.amazon.com/85110-115db-40...rds=piaa+horns These are lower tone: http://www.amazon.com/85112-115db-50...rds=piaa+horns
#13 |
thanks!
MicroImageonline forums - Shroomster Xda Forums - Shroomster Androidforums - Shroomster I'm noticing a pattern...... |
#14 | |
![]() ![]() ![]() Drives: 2012 Grey Toyota Yaris SE Join Date: Dec 2011
#15 |
I was wondering if the HIDs could be installed without taking the bunker completely off. If the fog light housing unclipped at all while its still attached to the bumper?
#16 |
![]() Drives: yaris Join Date: May 2013
Just started on my horn enhancement project - planning to use the air horns I had in my very first car (about 35 years ago!), as I just found them in the shed.
First thing I noted on my 2013 Yaris is that the 10mm fasteners at the bottom of the bumper are not all the same. Some are screws, which go into a clip-in plastic block, and others are bolts which thread into metal. And the pattern is not symetrical, so take notes, or pictures as you go, or just check that the fastener goes happily into the current hole. Cheers, Andrew |
| new front bumper spoiler and mags | nazier | Cosmetic Modifications (Exterior/Interior) | 3 | 07-24-2010 09:35 AM |
| FS: KavinT Manseth Kit (Front Bumper Damage) LIMITED TIME PRICE! | Treyz | Items for Sale by private party | 7 | 07-20-2010 03:57 PM |
| New mod: half silver front bumper paint job! | SAV912 | Photo-Video-Media Gallery | 9 | 07-18-2010 12:57 AM |
| FS: KavinT Manseth Kit (Front Bumper Damage) LIMITED TIME PRICE! | Treyz | Items for Sale by private party | 3 | 05-26-2010 08:43 PM |
