Old 07-10-2012, 06:34 PM   #1
tk-421
tk-421's Avatar
Drives: 5D-07-LB
While I agree that duplicate information is usually best shared in link form, I don't think it's all that terrible to have it pasted here instead, as long as the information is relevant to our cars, since it can be independently discussed.
BTW, If someone thinks the information being posted is incorrect, then by all means write it down so that we can all learn different points of view.
Old 07-11-2012, 06:27 AM   #2
Hussain-Vtec
Hussain-Vtec's Avatar
Drives: ECHO NCP-12/2NZ-FE
This is a Wise Minded thinking & i Totally Agree with you 100%.
The reason i posted this is so you guys can share your tests and results with oils, Do you no that the oil play a big Role in your Engine compression ratio.
Every one is locking from an angel & i respect that its ok guys i can take to
Much and handle more for the sake of good info for me & all of you.
Cheers
Hussain-Vtec is offline   Reply With Quote
Synth Blend Oils scape DIY / Maintenance / Service 7 07-12-2009 01:55 PM
Spilled oil on engine eii DIY / Maintenance / Service 11 01-28-2009 11:30 AM
Engine oil ddi not come out hans_fh DIY / Maintenance / Service 18 01-23-2009 11:30 PM
Compiled 1NZFE Used Oil Analysis craigq DIY / Maintenance / Service 7 09-10-2007 04:27 PM
