Old 07-11-2012, 11:45 AM   #1
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
And that for it can Hold your Engine compression ratio if you chose wisely.
Why do you think if they do a Engine compression test and put small amount
of oil on the top of the piston the Engine compression raise up.
Think of that!
You check compression as is. If you have low compression in a cylinder, then you put a small amount of oil in the cylinder to try and seal off your piston rings. If you still have low compression you are just ruling out that your piston rings are good.. Then you look for other problems like bent valves or head gasket.
My opinion on all this after doing many 3.0L desludges from ES300 and RX300, Just read your owners manual and go by thier scheduled services and the oil they recommend. I personally will use any full synthetic that is on sale that month with filter. 99% of the time sludge happens when people use conventional oil and skip out on thier expected oil changes.
-Derrick-
Old 07-11-2012, 12:00 PM   #2
Hussain-Vtec
Hussain-Vtec's Avatar
Drives: ECHO NCP-12/2NZ-FE
First thank you for post.
Second i have that issue like before 4 years & now I don't, i just share it to tel you guys some thing i Notice.
Regarding the Engine compression I no that, my point is if the oil is hot above
Its rating Numbers it get thin and for that it wont hold your piston Compression that's why when thy apply Oil's on piston to check the compression in a cylinder it will raise up due to the Cold oil or we can Say new oil applied on the pistons.
Hussain-Vtec is offline   Reply With Quote
Synth Blend Oils scape DIY / Maintenance / Service 7 07-12-2009 01:55 PM
Spilled oil on engine eii DIY / Maintenance / Service 11 01-28-2009 11:30 AM
Engine oil ddi not come out hans_fh DIY / Maintenance / Service 18 01-23-2009 11:30 PM
Compiled 1NZFE Used Oil Analysis craigq DIY / Maintenance / Service 7 09-10-2007 04:27 PM
