Old 07-18-2012, 07:23 PM   #1
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Hey Cranky,
Hadn't even thought about that. But I doubt it, maybe just hit them with a little fine emery cloth since I'm not running a top fuel dragster.
Did you notice anything about the outside runner holes?
We didn't undercut them as it would have added even more cost to the job. You had mentioned that as an issue, and we took the easy way around it...
The inner edges of the outer runners go straight down the edge of the head with no inner ledge. I'll simply feather out the inside edge of the runner tubing with a Dremel since the affected area is so small.
You should be able to the same thing to yours with no problems.
Old 07-18-2012, 11:16 PM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Originally Posted by tooter View Post
Hey Cranky,
Interesting. I was wondering how you would get around that. I had also considered something like that but with additional metal being added (welded) to that edge on the inside to meet the rim of the runner. Looks like it's coming along nicely, still can't wait to see how it performs!
Old 07-18-2012, 11:48 PM   #3
tooter
play every day
tooter's Avatar
Seeing how the adaptor actually turned out with such a small area with no ledge, it's really not much of an issue. I'll just knock the edge off from the inside.
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
