#19 |
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
it is just huge, ok :P
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
#20 |
Probably my fault, I thought it was -6AN, but I didn't measure it. Should have waited for pimp to post first.
-8AN
#21 |
C'est la vie
Drives: 2009 2 door hatchback Join Date: Aug 2009
I bought some -8 to -6 male fitting to go in the ends of the rail. -6an is enough flow for 800hp. I think that should cover it.
#22 |
C'est la vie
Got almost all my fittings together. I just need to get to work. I been feeling a little lazy lately.
#23 |
Looking good Aras/xbgod, would be nice to see one post without your usual sarcasm though.
I'll check the fittings tomorrow morning. Pimp has one in hand though, and if a -8 fits his, they are all made the same.
#24 |
Drives: 1nz-fe Join Date: Jul 2012
You know it! go big or go home at this point.
But please let your customers know it is 3/4 boss fitttings. You don't need any problems from a faulty install. Last edited by tk-421; 07-16-2012 at 05:13 PM. Reason: no need for the extra comments... |
#25 |
![]() ![]() ![]() ![]() Drives: Yaris Sedan 2009 Join Date: Sep 2010
So both end of fuel rail are -8an....but like pimp said....you put an adaptee -8 to -6 on each end...and them run -6an hose with appropriate hose ends ...
Am i right ? Garm can you get the adapter from the hard stock line to -6an fittings ?
Interior:ALL red, black roof Exterior:RTX scorpion painted GOLD, side and rear visor, oem spoiler, MI mesh grill, Hella supertone horn, RS badge, Vios badge, CF pillar, Led mirror cover, fog light HID 3000k, Projector retrofit HID 8000K Performance :MI CrankPulley, Tein springs, UR and TRD bar, TURBO IN PROGRESS Audio : Pionner DEH-80PRS, HAT L1V2, PowerBass 1100.5X 5 channel amp
#26 |
I can provide you with all the fittings based on whatever set up you want.
#27 |
I can have good prixe on hoses and fittings here in quebec...if you dont mind :)
Fuel rail will come from you of course :)
#28 | |
How much lenght is the hose ? What is this fuel regulator ? it looks good
#29 | |
C'est la vie
http://www.ebay.com/itm/Turbosmart-l...05%26rk%3D1%26 http://www.ebay.com/itm/170856323241...84.m1439.l2649 http://www.ebay.com/itm/180839939544...84.m1439.l2649 http://www.ebay.com/itm/230400476291...84.m1439.l2649 http://www.ebay.com/itm/180864287470...84.m1439.l2649 http://www.ebay.com/itm/310232698361...84.m1439.l2649 http://www.ebay.com/itm/180846322388...84.m1439.l2649 http://www.ebay.com/itm/260896688867...84.m1439.l2649 The bulkhead fitting will go in the top of the pump. I may also buy a -6 inline fuel filter. |
#30 |
Thank you pimp for all the information!! Which are very usefuel!!!
I could have waited for the fuel rail....but I was curious I like to know what to be waiting for....and you are right...these fittings are probably the same as the one they sell double price on summit racing or something :P
#31 |
C'est la vie
#32 |
it is cool what you are doing to your xB but I would prefer to see what you can do to a Yaris. 1 toasters don't seem very aerodynamic, where the Yaris is more aerodynamic than an xB (granted still not the most aerodynamic choice). 2 most people on here have a Yaris and would like to see your skills at working in the smaller engine compartment. just some input for ya "XFACOR".
#33 |
I'm pretty sure we only took off the drivers side ear. On the passenger side, a 90-degree fitting cleared.
#34 |
maybe you did it wrong :P
#35 |
#36 |
couldn't you notch the ear instead of removing it or would that still cause -8 clearance?
| The Nitrous Thread | ChinoCharles | Performance Modifications | 116 | 02-16-2016 03:07 PM |
| Yaris Fuel Pump | HTM Yaris | General Yaris / Vitz Discussion | 12 | 03-22-2012 03:34 AM |
| fuel rail | staypuft | Performance Modifications | 3 | 11-21-2008 09:43 AM |
