Old 11-20-2008, 09:42 PM   #1
staypuft
aka SDMF
staypuft's Avatar
Drives: 07 LB Met Met
fuel rail
does an aftermarket fuel rail have some kind of performance value if you are still using stock injectors? been looking at this
http://www.perrinperformance.com/pro...ory=7&model=17
staypuft is offline   Reply With Quote
Old 11-21-2008, 05:20 AM   #2
gboezio
gboezio's Avatar
Drives: Yaris 4dr 2008
Not even a tenth of a horsepower.
Power is related to the engine breathing capability Displacement X RPM X Volumetric efficiency.
If you had fuel pressure drop issues like with using a fat turbo with huge injectors, that would fix it tough.
gboezio is offline   Reply With Quote
Old 11-21-2008, 07:53 AM   #3
staypuft
aka SDMF
staypuft's Avatar
i do have the blitz compressor but it probably wont make a difference sending the fuel from stock to perrin's fuel rail
Old 11-21-2008, 09:43 AM   #4
correct. it won't deliver more fuel, and it if did, you'd have tuning issues.
Hang Time: Exploiting ECU Fuel Maps for Fuel Efficiency BailOut Fuel Economy Forum 20 11-13-2013 08:11 AM
Yaris Fuel Cutoff Switch Possible? Disturb3dMind3d General Yaris / Vitz Discussion 1 06-12-2007 05:32 PM
Increased MPG or HP anyone???? slvryaris Performance Modifications 55 05-27-2007 10:49 AM
Consumer Reports on Ethanol Driver General Yaris / Vitz Discussion 6 09-01-2006 11:21 AM
