#307 |
that beats the crap out of the original plastic manifold (not a fan).
did you get the throttle body plate done yet? |
#308 |
That's a rockin' setup!
![]() Nice job.
#309 | ||
play every day
![]() Quote:
![]() I took the prototype flange and drilled and filed and Dremeled all of the peripheral clearances into it so that the new measurement data can be taken off of the corrected part and fed into the CNC machine for the finished version. |
#310 |
Not to be a party pooper...but haven't you basically voided your warranty on just about anything that would pop a CEL?
If you want to enjoy your car, stay off of the internet. Last edited by Billiam; 08-03-2012 at 04:41 PM. |
#311 |
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
if it pops a CEL then he puts his OEM parts back on, resets the ecu but disconnecting the battery, and goes on. as far as warranty, it is amazing what can be done to car with out voiding it and in general you can get away with a lot of simple mods for intake and exhaust it just depends on if they can prove that any problem that arises is a direct result of the mods applied.
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
#312 | |
play every day
![]() ...and am happy to assume all of the responsibilities of owning a new vehicle. I don't buy used vehicles either... always new ones. |
#313 |
If you want to enjoy your car, stay off of the internet. |
#314 |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
Looks flippin awesome on there!
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
#315 |
Depot Damager
Drives: '08 Liftback Join Date: Jul 2012
Wait...that wasnt the final piece? Can i revise my numbers? Didnt know you were going to pull the old switcheroo... :)
2008 Yaris Liftback - Bought in '12 with 80k Sold in '17 with 180k Bought back in '20 with 270k Currently collecting parts for the 2zr swap |
#316 | |
play every day
You can change your guess any time right up until I do the dyno run. It would have been the final piece, but the flange had some fitment issues that needed refining so I resolved them today and the CNC guys will make a corrected part next week.
#317 |
advocatus diaboli
Looks great! Are you going to bling it up with a polished fuel rail?
#318 |
play every day
I'm a linear one-step-at-a-time person, and only focus my attention on what needs to be done right now.
I'm still at #1. ![]() 1. Flange Fit. 2. Throttle Body Fit. 3. Weld. 4. Blast. 5. Clean. 6. Dyno. |
#319 |
1 million HP.
#320 | |
advocatus diaboli
I get that, but I'd still put fuel rail in there somewhere so I didn't have to take all that stuff apart, maybe 5.5.
#321 |
5a. Drive
5b. Disconnect the battery to clear the CEL (after noting the error code) 5c. Repeat. Just kidding, I am truly hoping those steps aren't included.
#322 |
2ZR swap. DO IT! Ask how!
#323 | |
play every day
![]() You know far more about that than I do since you have years of experience with your manifolds and are a lot farther along in the process than I am. They certainly have to have been test run by now. Have any of your own short or longer runner manifolds triggered check engine lights? And if they did, how did you address them? One decided advantage is that the throttle body and engine on either side of my manifold are in exactly the same bone stock condition as with the OEM manifold. So with the manifold itself as the only change I don't anticipate any issues. With no alteration of the size or profile of the actual entry and exit ports, utilizing all of the stock gasketing to insure a leak free design, and designing all of the adaptations to be smoothly transitioned, I'm optimistic that it will be just fine. The check engine light issue would be greatly complicated if there were other concurrent changes being made. It would be much more difficult to address. This is why I'm focused just on making this one mod and nothing else. |
#324 |
play every day
It was perimeter clearances. The top of the flange needs to be milled down 1mm to clear the stock fuel rail supports. It's really close, as I was able to drop in the flange easily just by slightly loosening the fuel rail bolts. There is a cylindrical sensor close on the left side so I filed a semicircle to clear it. Also at the center of the fuel rail there's a part underneath it which also needed a semicircle filed to clear.
They were minor and corrected with a file. The goal is to make the flange simply drop in. How are you doing on yours? I hope that sharing the details of the process will help to move your manifold along.
| homemade intake manifold | ttr125fan09 | Performance Modifications | 1 | 02-17-2012 01:09 AM |
| Custom Intake Manifold + Direct Port Nitrous | blacksandiegovitz | Performance Modifications | 9 | 04-21-2010 07:05 PM |
| Turbo Manifold thread | Sabretooth | Forced Induction Forum | 78 | 05-22-2009 06:52 AM |
| turbo manifold build... | joey1320 | Forced Induction Forum | 4 | 06-30-2007 02:26 PM |
