Old 07-24-2012, 01:56 AM   #17
PatrickJohnson
Drives: 2008 Yaris LB
Solved! Since the 2012 I bought from Garm (model t1817) is a Pioneer, I used the info in the below link and transposed it to this model to add a normal USB jack on the back. Problem solved.
http://www.toyota-4runner.org/audio-...installed.html
Even though the USB connector on the back isn't of quite the same type, the connections on the USB daughter board inside the radio are labeled the same as in that write-up, so I wired up the end from a short USB extender I had and VOILA! USB port.
So I can install my own USB port somewhere and run the cable to that port. As for the AUX, I should be able to use my existing connector from the OEM AUX jack I would think. Thoughts?
(I'll try to make time this weekend to do my own DIY for this model since the board is different from the one in the above write-up)
PatrickJohnson is offline   Reply With Quote
DIY - Carbon fiber wrapping Brian Wash, Wax, Detailing, Exterior Repairs 15 07-10-2016 12:34 PM
Part #s for Fog Light install? Can anyone who works for Toyota confirm? IsLNdbOi Cosmetic Modifications (Exterior/Interior) 73 12-23-2010 05:15 PM
2008 OEM S model Liftback Lip kit Part numbers PETERPOOP Cosmetic Modifications (Exterior/Interior) 17 07-26-2010 01:33 PM
NEED HELP - Yaris suspension part Trish General Yaris / Vitz Discussion 10 11-07-2009 01:44 PM
Buying One Specific Part.... hasher22 General Yaris / Vitz Discussion 2 08-26-2006 09:57 AM
