![]() ![]() ![]() Drives: '08 Blazing Blue Yaris LB Join Date: Sep 2009
Power window noise
My '08 Yaris LB passenger side power window recently started to make a sort of buzzing friction noise when it goes up. The window still operates well but I am concerned about the noise. I lubricated the tracks but it didn't help. Does anyone know what's the cause and fix for this? Thanks :o)
Sounds like something with the motor or the lifting assembly. I would pull the door panel to get a better look/hear.
Will do. :o)
I removed the door panel to have a look and sure enough the noise was coming from the power window motor. I sprayed some lithium grease on the gear and greased the metal track below. None of this helped much though.
How much longer would you guess it will be before the motor is likely to die? When it does need replacement it looks like a bear of a job to get the old motor out and a new one in. Has anyone replaced a window motor? Last edited by birdman; 07-25-2012 at 12:23 AM. |
#5 | |
Thank you. :o)
#7 | |
![]() Drives: 2008 Yaris Sedan Join Date: Nov 2008
![]() I wondered if it's actually something in gearing or spacing (ie loose and rubbing) unique to the RHS Front door topology but you say you took the panel off already and it's coming from the motor module. I don't know how cheap this is parts wise but usually it's not too bad of a DIY job. I did it three times on my old Lumina Van (1 driver, 2 passenger; it was a '95 that is just going out to pasture now). Sounds like wait till it dies kind for thing but if it becomes an epidemic we might get lucky with a TSB. Did you look already? FYI Mine was a 12/07 build date and if I decode the VIN correctly it was plant "1" in Japan. |
#8 | |
Hmm. Pretty strange since the driver's side gets rolled down a lot more and, as you can see from my profile location in Edmonton, we don't roll down windows at all almost half the year. Also, from prior power window experience, 4 years is really a poor lifetime; I'd expect twice that.
![]() ![]() ![]() Drives: 2007 White Toyota Yaris Type S Join Date: Dec 2006
If this helps at all.. My front passenger window motor has made a "struggling to roll up type of noise" id say for about the past 3 years.. It doesnt roll up or down any slower or faster than the driver side.. It just makes the noise.. So like CTscott said, it could die tomorrow or never..
I think its from lack of use mostly. Mine is louder too. I only roll it down about an inch when I leave it in the parking lot at work otherwise it gets barely any use. I think the drivers side is more smooth because of daily use....
| Yaris Power window switch fires | auxmike | General Yaris / Vitz Discussion | 7 | 06-21-2012 03:41 PM |
| Ohm's Law and Setting Amp Gain | _S7V7N_ | In Car Entertainment + Electronics (audio / video / alarm) | 24 | 03-13-2012 10:34 PM |
| Installation of original power windows and locks in Yaris | lantis | DIY / Maintenance / Service | 4 | 02-25-2012 02:38 PM |
| When will the Yaris hit the showrooms at dealers? | Petrolhead | New YARIS Purchase Forum | 181 | 11-28-2011 08:03 AM |
| Rear Window Defogger | YarisOwnersDad | New YARIS Purchase Forum | 37 | 12-10-2010 12:31 AM |
