Old 08-26-2012, 01:28 PM   #8
Originally Posted by DaryleTilroe View Post
Came here to look for this symptom. My '08 Yaris Sedan has started doing *EXACTLY* the same thing on *EXACTLY* the same window. Are they on some sort of failure timer!? Of course it's a year off warranty.
I wondered if it's actually something in gearing or spacing (ie loose and rubbing) unique to the RHS Front door topology but you say you took the panel off already and it's coming from the motor module.
I don't know how cheap this is parts wise but usually it's not too bad of a DIY job. I did it three times on my old Lumina Van (1 driver, 2 passenger; it was a '95 that is just going out to pasture now).
Sounds like wait till it dies kind for thing but if it becomes an epidemic we might get lucky with a TSB. Did you look already?
FYI Mine was a 12/07 build date and if I decode the VIN correctly it was plant "1" in Japan.
There is not a TSB on this. It is not a very common issue and probably has much to do with the frequency that the power windows are opened and closed.
Yaris Power window switch fires auxmike General Yaris / Vitz Discussion 7 06-21-2012 02:41 PM
Ohm's Law and Setting Amp Gain _S7V7N_ In Car Entertainment + Electronics (audio / video / alarm) 24 03-13-2012 09:34 PM
Installation of original power windows and locks in Yaris lantis DIY / Maintenance / Service 4 02-25-2012 01:38 PM
Rear Window Defogger YarisOwnersDad New YARIS Purchase Forum 37 12-09-2010 11:31 PM
