#379 |
http://www.yarisworld.com/forums/sho...=throttle+body
http://www.yarisworld.com/forums/sho...=throttle+body there's been a few threads on it... |
#380 |
2ZR swap. DO IT! Ask how!
There have been very mixed results with the 4-bolt DBW Corolla TBs, ranging from no issues to abject failure. They are electrically compatible, but the only real benefit from using one (w/o engine management) is that you effectively open the throttle faster. The corolla has a larger diameter TB, so you allow more air flow for the same throttle signal.
Beyond that, I really don't know the specifics. There's the potential to lean out your AFR too much at WOT because the ECU isn't expecting that much air to be available, and the stock fuel maps may cause it to misbehave. Going to a 3-bolt, cable throttle with a separate throttle position sensor (TPS) is only practical with standalone engine management (this is how Garm gets away with it) due to unresolved issues with the stock TPS signal. I believe that CTScott poked around with a scope and meter on a stock TB but wasn't able (?) to make sense of the signals. There has been a good deal of debate and experimenting with this, but no magic bullet solution. It mostly comes down to the stock ECU being a "learning" unit, and it's not happy with signals outside of the expected range. |
#381 |
play every day
Thanks for the threads, Blue.
![]() I don't think I want to get involved in drilling out rivets, swapping chips, cracking idle screws, and rerouting coolant lines just now. Right now I'm focused on just one project... the manifold. Things turn out the best when I only do one thing at a time.
#382 | |
#383 |
play every day
Thanks for the info, Garm.
![]() I know nothing about forced induction, and just figured that the stock plastic OEM manifold was designed for vacuum and not pressure. |
#384 |
![]() ![]() ![]() ![]() Drives: Yaris Sedan 2009 Join Date: Sep 2010
where did you bought the oem gasket ?
I will need to pickup a bunch of gasket :)
Interior:ALL red, black roof Exterior:RTX scorpion painted GOLD, side and rear visor, oem spoiler, MI mesh grill, Hella supertone horn, RS badge, Vios badge, CF pillar, Led mirror cover, fog light HID 3000k, Projector retrofit HID 8000K Performance :MI CrankPulley, Tein springs, UR and TRD bar, TURBO IN PROGRESS Audio : Pionner DEH-80PRS, HAT L1V2, PowerBass 1100.5X 5 channel amp
#385 |
play every day
Test fitting time...
![]() ![]() It's a drop in fit! Did a little fine tuning with the Dremel. Since these were both undercuts, I just did them by hand... ![]() ![]() Clears the fuel rail perfectly with ~almost~ zero clearance... ![]() Ports matched flawlessly... ![]() Next up: test fit the throttle body.
#386 |
play every day
The flange is now a drop in fit, the throttle body bolts onto the adaptor like a dream, and the rest of the manifold has no clearance issues... ( goody
)![]() ![]() ![]() ![]() ![]() ![]() However... nothing else fits! ![]() All of the hoses are going to need rerouting, and I'm going to have to find a way to (gulp!) lose 2 3/4 inches on the already super short ram intake to make the air filter fit. But these issues are minor compared to getting the manifold itself to work out. |
#387 |
![]() ![]() ![]() ![]() ![]() Drives: red bare bone yaris hb 3dr Join Date: May 2009
Wow I like how the first pic look !
#388 |
you should do a little cleanup of the head while the flange has no runners on it. would make it SUPER easy to 100% port match it and get rid of the casting marks.
#389 |
Mr. 155 and climbing
this work is SO much fun to watch. i applaud you.
#390 |
play every day
If the head was off the engine I'd give it a whirl. But with the head on, I don't want to risk getting metal chips in the engine.
#391 |
play every day
#392 |
#393 |
how much for the flange and adaptor ? can you hve other one made ? :D
#394 | |
play every day
There's also another reason... that would be making two changes at once, so I wouldn't be able to accurately quantify the difference on the dyno with just the manifold itself. But, hey, you're perfectly free to grind your head if you want. The manifold can be glass beaded because afterwards it can be hot tanked to insure that every particle of blasting medium is gone. Being a junkyard part, it's totally filthy and sticky inside and would need professional cleaning even if it wasn't blasted. It's hard to make out, but this was the original condition... ![]() The runners are all as dirty as those ports, and all the way through, as well as the complete inside of the plenum. There is an intake port that extends into the middle of the plenum which makes it impossible to clean without being totally immersed. |
#395 | |
http://youtu.be/oet4qWeZuYA |
#396 | |
play every day
But IF this works (and, man, that's a really big IF )... ...I do think that the mounting flange, throttle body adaptor and its 3 mounting bolts, and all 3 gaskets would make a really neato "do-it-yourself" kit. Then you could simply get your own junkyard manifold and finish it up any way you'd like. |
| homemade intake manifold | ttr125fan09 | Performance Modifications | 1 | 02-17-2012 01:09 AM |
| Custom Intake Manifold + Direct Port Nitrous | blacksandiegovitz | Performance Modifications | 9 | 04-21-2010 07:05 PM |
| Turbo Manifold thread | Sabretooth | Forced Induction Forum | 78 | 05-22-2009 06:52 AM |
| turbo manifold build... | joey1320 | Forced Induction Forum | 4 | 06-30-2007 02:26 PM |
