Old 07-29-2012, 09:44 AM   #1
packetrace
packetrace's Avatar
Drives: Yaris Sedan 2009
how much for the flange and adaptor ? can you hve other one made ? :D
Interior:ALL red, black roof
Old 07-29-2012, 12:55 PM   #2
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
First I need to know if this setup will even work decently. That will determine whether or not it would be worth your while. We'll all find out if it's "go" or just "show" after the prototype has been run on the dyno.
But IF this works (and, man, that's a really big IF )...
...I do think that the mounting flange, throttle body adaptor and its 3 mounting bolts, and all 3 gaskets would make a really neato "do-it-yourself" kit.
Then you could simply get your own junkyard manifold and finish it up any way you'd like.
Old 07-29-2012, 06:45 PM   #3
enviri
enviri's Avatar
Drives: 2010 Yaris
soo your manifold is off a 1zz drive by cable? If we got hold of the dbw 1zz with the 4 bolt throttle body, would we just need the mounting flange only?
*confused*
Old 07-29-2012, 06:59 PM   #4
tooter
play every day
tooter's Avatar
Yes. It's off of an 1998-2003 Toyota Corolla 1.8L 1ZZ-FE engine with a 3 bolt cable operated throttle body.
*confused*
The adaptor only adapts the Corolla 1ZZ-FE 3 bolt cable controlled throttle body manifold to the Yaris 1NZ-FE 4 bolt electronically controlled throttle body.
Old 07-29-2012, 08:13 PM   #5
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Not entirely true: the Corolla 4-bolt TB is the same mounting pattern, just with a larger diameter hole/valve.
Old 07-29-2012, 09:41 PM   #6
tooter
play every day
tooter's Avatar
Oh, right... that was the one that people were trying to get to work. The hole in my adaptor is sized to fit the stock Yaris throttle body.
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
