Old 08-09-2012, 02:31 PM   #1
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
you could repaint it or just replace the whole thing.
right below the section in question, there s a small plastic insert that is covering the nut which holds it to the stud. just remove the plastic insert and take the nut off. the wiper comes right off. the wiper is ribbed (there is a propper word for it but it eludes me) so that it will turn with the movement of it.
I actually used the dirt on my windshield for alignment when I removed mine. I had to remove my cowl for spring removal.
good luck regardless of what you decide to do.
Old 08-09-2012, 07:06 PM   #2
Lux
Lux's Avatar
Drives: NCP91
Corrosion on the surface could mean corrosion on the splines beneath it which attach the arms to the motor. Don't bother playing doctor dress-up and just replace the arm altogether.
Splined
Lux is offline   Reply With Quote
Old 08-09-2012, 09:44 PM   #3
WTF are you talking about!? I have never seen spline corrosion on any wiper arm that exhibits this common problem of paint blistering on this part of the arm.
Hey everyone...Did anyone get a FIX for the Oversteer Problem at fwy Speeds under war jay cobbs General Yaris / Vitz Discussion 0 06-13-2012 10:10 AM
DIY- rattle from lower windshield fix. PetersRedYaris DIY / Maintenance / Service 3 08-21-2011 12:29 AM
LED Indicator Fast Flash Plug and Play FIX 1NZYaris1 In Car Entertainment + Electronics (audio / video / alarm) 5 04-18-2011 03:47 AM
Uh oh: How Much To Fix This? bronsin General Yaris / Vitz Discussion 11 12-05-2009 07:25 PM
firts mecanic fix! the_boss Off-topic / Other Cars / Everything else Discussions 1 08-21-2009 03:56 AM
