jqueza@microimage
Drives: 2010 vios Join Date: Apr 2012
are you sure ct dont want to spend 100 when i can spend 40$$
Yes. But, the difference between these $40 ones and the MicroImage $100 kit is that the MicroImage one includes the wiring pieces developed by Ray (1NZYaris1), which allow you to install them using the existing factory wiring through the firewall.
If you are installing them yourself this saves a large amount of work, as the $40 kit will require you to pull the battery and wiper tray to get at the firewall grommet to run the harness through the firewall. To modify the $40 kit to use the factory wiring you would need to purchase the two pins for the under-hood fuse panel connector ($12+ each) and the fog light relay for the under-dash fuse panel ($20).
#3 | |
jqueza@microimage
| my Projector Fog lights project | ezhacker1 | Cosmetic Modifications (Exterior/Interior) | 3 | 01-10-2010 05:21 PM |
| Fog Lights Poll | Reeves360 | Cosmetic Modifications (Exterior/Interior) | 14 | 12-27-2009 02:00 AM |
| Fitting Front Fog Lights OEM - Yaris 2007 3dr | weller | Cosmetic Modifications (Exterior/Interior) | 1 | 12-17-2009 12:29 PM |
| Installed my ebay sedan fog lights today and trd grill badge.... | YarisSedan | Cosmetic Modifications (Exterior/Interior) | 9 | 11-20-2009 09:54 PM |
| fog lights, cost of installing them at the dealership? | kuyachris84 | Cosmetic Modifications (Exterior/Interior) | 33 | 05-24-2009 07:05 PM |
