Old 08-15-2012, 06:58 PM   #1
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
Fuel pressure is set at 45psi at idle.
And yes I am increasing turbo boost because that is the whole point of getting enough fuel to support it.
I was beyond maxing the stock in tank fuel pressure regulator at 12psi
I am running into a new problem in trying to get to 15psi. It looks like my current .48AR turbine turbo will not flow enough air to maintain 15psi. I am getting to 16psi now, but as rpm,s go up boost is falling off. Time for a new turbo and a new manafold.
This is what Im liking
http://www.ptuning.com/html/Item-Des...9&ModelDesc=xB
Plus a tial external wastegate and a .64AR hot side turbo with a new custom 3 inch exhaust.
pimp my yaris is offline   Reply With Quote
Old 08-28-2012, 11:19 PM   #2
Scubaru Steve
Awesome!
Drives: 12 Yaris/07 yaris
the higher a/r will easily add top end and help increase boost, you will lose spool, as in it will take a few more revs to spool the turbo.
id go with a .63.
Old 08-28-2012, 11:37 PM   #3
pimp my yaris
C'est la vie
id go with a .63.
Yes thats the plan. And I definitly need the external wastegate. The internal gate does not move fast enough when cranking up the boost.
Under $2500 Turbo Kit w/Intercooler coming soon! cdydjded Forced Induction Forum 58 09-23-2007 02:02 PM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 15 06-09-2007 01:24 AM
ZPI soon to release their turbo kit turboyaris Forced Induction Forum 10 04-26-2007 02:52 PM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 30 04-04-2007 02:10 PM
