Old 08-20-2012, 03:43 PM   #1
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
With crash bolts I only got -1.5 and I needed to slot the holes to get an additional -1.5. Your neg camber can also vary depending on how much you've lowered the car as well so if Garm's lowered 3" hes going to be pretty deep into his camber curve whereas if you've only dropped an inch you won't have much camber gain. Remember suspension travels on a slight arc.
The right left readings will always be there because there is always tolerances built into everything. The .3 difference is meaningless and isn't even noticeable in most applications.
As for your rubbing you have +20 offset wheels that are 8" wide and with the relatively light spring rate in the rear with the megans and possibly a car that's been lowered to far you'll get rubbing when you hit a bump or turn hard or even have a few heavy passengers in the back.
Old 09-20-2012, 02:35 PM   #2
DeathBeard
DeathBeard's Avatar
Drives: 2010 Yaris S
did you use a 7/16 drill bit to slot the struts? I'm assuming you used the top hole?
"In his heart a man plans his course, but the Lord determines his steps."
Proverbs 16:9
DeathBeard is offline   Reply With Quote
Old 09-20-2012, 04:28 PM   #3
xnamerxx
0-60 in slow
xnamerxx's Avatar
I used a die grinder and a carbide bit but I couldn't tell you the size it was just something I grabbed from the shop. I slotted it out to the edge mark of the bolt on the upper bolt hole it give you an idea of how far I went out.
A drill bit would make the job take quite a bit more time FYI since most of the shocks are thick DOM.
Old 09-22-2012, 12:51 AM   #4
DeathBeard
DeathBeard's Avatar
is your die grinder hooked up to air? i dont have access to a compressor
Proverbs 16:9
Old 09-22-2012, 12:56 AM   #5
DeathBeard
DeathBeard's Avatar
http://www.yarisworld.com/forums/sho...d.php?p=562723
Proverbs 16:9
Old 09-22-2012, 01:01 AM   #6
xnamerxx
0-60 in slow
xnamerxx's Avatar
The die grinder was pneumatic but a dremel works as well its just slower. I wouldn't use a drill only because it'll take a really long time.
If you look at his picture the only thing you actually need is the silver piece it pops right off the mount that silver piece is the actual bearing the black piece is the spring support which isn't be needed.
Old 09-22-2012, 05:01 PM   #7
DeathBeard
DeathBeard's Avatar
Ok so take the "silver piece" press it into the red top plate provided by megan put the stock black donut on and install? The thing confusing me was if we had to reuse the top oem black springplate or not
Proverbs 16:9
Old 09-21-2012, 04:13 PM   #8
xnamerxx
0-60 in slow
xnamerxx's Avatar
By top hole I assume you mean the upper of the 2 bolts that secure the strut to upright not the upper bolt hole that secures the strut to the chassis.
Old 09-22-2012, 12:41 AM   #9
DeathBeard
DeathBeard's Avatar
yes like this
Proverbs 16:9
Megan Racing header install and review with pics. Herbicidal Performance Modifications 6 09-03-2009 08:40 AM
Pre Hack Revival: Megan Racing Header vs Ebay Header Sabretooth Performance Modifications 15 08-19-2009 05:26 PM
Megan coilover fitment problem YaYa1320 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 08-06-2009 08:01 PM
Megan Coilover install DIY kapo DIY / Maintenance / Service 5 09-24-2007 07:20 PM
Megan or Tein suspension elmercurrie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 43 05-31-2007 09:41 PM
