![]() ![]() Drives: 2008 Yaris HB MT Join Date: Jan 2009
If the weapon-r manifold made the claimed amount of horsepower you know there would be dyno charts to support it. It doesn't, so there are none. I am surprised there are seriously nearly zero charts online. Some google image searches show some charts paired up with other mods, and none of those charts show large gains over what I/h/e are worth.
I'm excited to see this MicroImage manifold. If they are so close to a finished product there is no sense in building my own right now. My ideas from working on NA Hondas in the past was you could improve the plenum design of the weapon-r, as well as add velocity stacks to each intake port inside the manifold. Maybe the problem with the weapon-r is they were trying to find a balance between NA and FI performance? |
#2 | ||
play every day
The actual performance of an intake manifold can be muddied up with other concurrent mods like intake, throttle body, injectors, fuel, e tuning, or exhaust, so that you never actually know whether or not an increase was in the manifold. This is why I did the two sets of runs with the manifold as the only change, so that I would have an accurate assessment of it alone. Quote:
And that makes sense. From what I've read, forced induction plenums need to be larger than normally aspirated ones so that one plenum size cannot ideally fit both. But a single plenum size compromise between the two could work less than ideally for both. |
#3 | |
![]() ![]() Drives: Yaris '06 Join Date: Apr 2011
Same as power - you want to make power - you can forget about fuel economy ^^ btw i like the matt black stealth look :) |
#4 | |||
play every day
Coincidently, one of the CNC guys at Origin Design in Santa Monica worked on the design of this manifold. Quote:
| homemade intake manifold | ttr125fan09 | Performance Modifications | 1 | 02-17-2012 01:09 AM |
| Custom Intake Manifold + Direct Port Nitrous | blacksandiegovitz | Performance Modifications | 9 | 04-21-2010 07:05 PM |
| Turbo Manifold thread | Sabretooth | Forced Induction Forum | 78 | 05-22-2009 06:52 AM |
| turbo manifold build... | joey1320 | Forced Induction Forum | 4 | 06-30-2007 02:26 PM |
