Old 08-27-2012, 03:49 AM   #1
ljming99
Drives: Yaris '06
And that makes sense. From what I've read, forced induction plenums need to be larger than normally aspirated ones so that one plenum size cannot ideally fit both. But a single plenum size compromise between the two could work less than ideally for both.
Thats why i said earlier as well, there is "no best of both worlds" ..more of a balance / compromise. The length of the intake was a very good example.
Same as power - you want to make power - you can forget about fuel economy
^^ btw i like the matt black stealth look :)
ljming99 is offline   Reply With Quote
Old 08-27-2012, 10:49 AM   #2
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
In efforts to bridge that compromise gap, engineers even went so far as to design dual length runner intake manifolds like this Ford Taurus SHO intake manifold for their Yamaha engine, which just has to be one of the most intriguing engines ever to be found in a Ford...
Coincidently, one of the CNC guys at Origin Design in Santa Monica worked on the design of this manifold.
That's been one of the unintended consequences of the tooter manifold. My gas mileage average has been consistently higher by about 1.5 mpg and I'm not really sure exactly why. One guess is the combination of its overall smaller volume and slightly longer runners.
How about this silver one?
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
