#811 |
play every day
Drives: 2012 Yaris L 2dr 5sp Join Date: Apr 2012
No problem, Garm.
![]() We're on the same side. |
#812 | |
play every day
![]() I want to know what they look like just to be sure that I'm ordering the right one. The bore diameters are so close between the 1NZ FE and 1ZZ FE I may have the rest of the adaptors all machined 1ZZ sized so that the manifold will work for both throttle bodies. |
#813 | |
2ZR swap. DO IT! Ask how!
I'm not sure what constitutes "close" here, but a solid step will cause some significant turbulence. I would honestly suggest making two different adapters, assuming you're not opposed to having additional inventory eating up shelf space. |
#814 |
It would be a reverse step (if you can even call it that) if the flange is 1zz and a smaller 1nz throttle is mounted on it, and it's after the the throttle. That's how our test car is set up.
I don't know if that's going to make much of a difference.
#815 | |
play every day
There won't be much inventory anyways.
#816 |
Here's a pic of a 1ZZ TB from the manifold side. If you need/want a different angle or direct measurements, I can scare those up too. I bought one from fleaBay for $50 and ended up sacrificing it to the techno-god "Howzitwerk" to see if it could be disassembled, cleaned, and reassembled. Turns out the answer to that is a resounding NO.
Oh, and the .pdf is a measured drawing that I made of the basic dimensions. If the picture looks like it's mirrored from the drawing, it's because the right half of the drawing is the face of the manifold, not the TB. Last edited by CrankyOldMan; 08-29-2012 at 03:00 PM. |
#817 |
"Know it all"
Drives: Lancia Delta Integrale Join Date: Jan 2012
Tooter, we have a couple of 1ZZ throttle bodies available here if you want to pick one up.
www.microimageonline.com |
#818 | |
#1 Lemming
Drives: Light Blue '08 Yaris Join Date: Mar 2010
#819 | |
![]() ![]() ![]() ![]() Drives: Yaris Sedan 2009 Join Date: Sep 2010
Interior:ALL red, black roof Exterior:RTX scorpion painted GOLD, side and rear visor, oem spoiler, MI mesh grill, Hella supertone horn, RS badge, Vios badge, CF pillar, Led mirror cover, fog light HID 3000k, Projector retrofit HID 8000K Performance :MI CrankPulley, Tein springs, UR and TRD bar, TURBO IN PROGRESS Audio : Pionner DEH-80PRS, HAT L1V2, PowerBass 1100.5X 5 channel amp
#820 |
"Know it all"
Yes
You can't have one.
#821 |
#822 |
He has a dryyyyy sense of humor.... unless he meant it. LOL
#823 |
"Know it all"
PM Replied and emailed you also.
I was joking
#824 |
#825 |
play every day
Thanks, Jeff. Cranky's pic did the job. I just wanted to see if the bore was equidistant from the 4 studs so that the adaptor bore diameter can be adjusted accordingly from tapering down to 48mm to straight 51mm.
#826 | |
play every day
![]() It looks like a simple straightforward change to make the adaptor 51mm to match the 1zz throttle bore. That will make three possible tooter options: 1NZ 4 bolt 48mm 1ZZ 4 bolt 51mm 1ZZ 3 bolt 51mm |
#827 |
![]() ![]() Drives: scion xb Join Date: May 2010
interesting tread.... weird thing is today my coworker was throwing some car parts away.. one of it is 1zz celica intake manifold.. and i was looking at it.. and in my head.. look like it can fit the yaris... i told him hold on to it so i can do more research on it.. so I'm guessing it is possible..
#828 |
It won't fit. Its the same as the aluminum one, but plastic.
| homemade intake manifold | ttr125fan09 | Performance Modifications | 1 | 02-17-2012 01:09 AM |
| Custom Intake Manifold + Direct Port Nitrous | blacksandiegovitz | Performance Modifications | 9 | 04-21-2010 07:05 PM |
| Turbo Manifold thread | Sabretooth | Forced Induction Forum | 78 | 05-22-2009 06:52 AM |
| turbo manifold build... | joey1320 | Forced Induction Forum | 4 | 06-30-2007 02:26 PM |
