Old 08-28-2012, 07:13 PM   #811
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
No problem, Garm.
We're on the same side.
Old 08-28-2012, 10:01 PM   #812
tooter
play every day
tooter's Avatar
Originally Posted by CrankyOldMan View Post
The mating surface of the TB is flat, just like the 1NZ. I've got one in the shed if you want pics for sketching/brainstorming.
Just one pic would be great, Cranky.
I want to know what they look like just to be sure that I'm ordering the right one.
The bore diameters are so close between the 1NZ FE and 1ZZ FE I may have the rest of the adaptors all machined 1ZZ sized so that the manifold will work for both throttle bodies.
Old 08-29-2012, 07:26 AM   #813
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I've got some homework to finish up this morning, but if I have time before class, I'll snap a few.
I'm not sure what constitutes "close" here, but a solid step will cause some significant turbulence. I would honestly suggest making two different adapters, assuming you're not opposed to having additional inventory eating up shelf space.
Old 08-29-2012, 10:29 AM   #814
It would be a reverse step (if you can even call it that) if the flange is 1zz and a smaller 1nz throttle is mounted on it, and it's after the the throttle. That's how our test car is set up.
I don't know if that's going to make much of a difference.
Old 08-29-2012, 12:14 PM   #815
tooter
play every day
tooter's Avatar
Thanks for the good advice. I'll do that.
There won't be much inventory anyways.
Old 08-29-2012, 01:25 PM   #816
CrankyOldMan
Here's a pic of a 1ZZ TB from the manifold side. If you need/want a different angle or direct measurements, I can scare those up too. I bought one from fleaBay for $50 and ended up sacrificing it to the techno-god "Howzitwerk" to see if it could be disassembled, cleaned, and reassembled. Turns out the answer to that is a resounding NO.
Oh, and the .pdf is a measured drawing that I made of the basic dimensions. If the picture looks like it's mirrored from the drawing, it's because the right half of the drawing is the face of the manifold, not the TB.
Old 08-29-2012, 05:40 PM   #817
Jeff@MicroImage
"Know it all"
Jeff@MicroImage's Avatar
Drives: Lancia Delta Integrale
Tooter, we have a couple of 1ZZ throttle bodies available here if you want to pick one up.
www.microimageonline.com
Jeff@MicroImage is offline   Reply With Quote
Old 08-29-2012, 05:58 PM   #818
suckerface
#1 Lemming
suckerface's Avatar
Drives: Light Blue '08 Yaris
Just to clarify, they're the -030 parts, correct?
Old 08-29-2012, 06:00 PM   #819
packetrace
packetrace's Avatar
Drives: Yaris Sedan 2009
how much do you sell them ?
Interior:ALL red, black roof
Old 08-29-2012, 06:05 PM   #820
Jeff@MicroImage
"Know it all"
Yes
You can't have one.
Old 08-29-2012, 06:08 PM   #821
packetrace
packetrace's Avatar
You can't have one.
YGPM...
Old 08-29-2012, 06:24 PM   #822
He has a dryyyyy sense of humor.... unless he meant it. LOL
Old 08-29-2012, 06:25 PM   #823
Jeff@MicroImage
"Know it all"
YGPM...
PM Replied and emailed you also.
I was joking
Old 08-29-2012, 07:39 PM   #824
packetrace
packetrace's Avatar
I was joking
LOLLL
Old 08-29-2012, 09:15 PM   #825
tooter
play every day
tooter's Avatar
Thanks, Jeff. Cranky's pic did the job. I just wanted to see if the bore was equidistant from the 4 studs so that the adaptor bore diameter can be adjusted accordingly from tapering down to 48mm to straight 51mm.
Old 08-29-2012, 09:21 PM   #826
tooter
play every day
tooter's Avatar
Hey, thanks Cranky!
It looks like a simple straightforward change to make the adaptor 51mm to match the 1zz throttle bore. That will make three possible tooter options:
1NZ 4 bolt 48mm
1ZZ 4 bolt 51mm
1ZZ 3 bolt 51mm
Old 08-30-2012, 01:42 AM   #827
chexmix
Drives: scion xb
interesting tread.... weird thing is today my coworker was throwing some car parts away.. one of it is 1zz celica intake manifold.. and i was looking at it.. and in my head.. look like it can fit the yaris... i told him hold on to it so i can do more research on it.. so I'm guessing it is possible..
chexmix is offline   Reply With Quote
Old 08-30-2012, 07:25 AM   #828
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
It won't fit. Its the same as the aluminum one, but plastic.
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
