Old 08-29-2012, 07:41 PM   #1
MUSKOKA800
MUSKOKA800's Avatar
Raise the car so a rear wheel is off the ground and then try moving the top of the tire in and out. If a bearing is going there should be some unwanted play/looseness. Lower and repeat at the other side.
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-05-2008 11:37 PM
Front Wheel Bearing Failure craigq DIY / Maintenance / Service 4 08-17-2007 07:26 AM
