On the Yaris both are relatively easy. The "Drive Shaft" section of the service manual explains the process (download from the Micro Image forum: http://www.microimageonline.com/foru...32-YARIS-FILES).
Basically, you drain the tranny, remove the wheel, remove the axle nut, disconnect the tie rod end, stabilizer link, and ball joint, pull the steering knuckle off of the shaft, and then pop the drive shaft out of the tranny. When I did Crashy's, the hardest part was getting the axle nut off. As for replacements, I bought a junkyard one for $50 off ebay that was in perfect shape.
#2 | |
![]() Drives: Yaris 2007 Join Date: Oct 2013
So there's no two way about it? tie rod end, stabilizer link and ball-joint all have to be disconnected in order to finish the job? I'll need to find the torque specs for all these things... |
| Yaris Oil Change DIY | rningonfumes | DIY / Maintenance / Service | 91 | 01-11-2019 07:18 PM |
| ***The Engine Oil Bible*** | Hussain-Vtec | Performance Modifications | 20 | 09-28-2016 02:47 PM |
| Add another hard drive to a laptop? | CompanyXPaladin | Off-topic / Other Cars / Everything else Discussions | 4 | 11-23-2008 12:18 PM |
| external hard drive questions | Shroomster | Off-topic / Other Cars / Everything else Discussions | 10 | 11-23-2008 04:46 AM |
| Anyone know how the passenger seat detection system works? | rage2 | DIY / Maintenance / Service | 5 | 05-12-2007 07:22 PM |
