Old 08-29-2012, 07:49 PM   #2
On the Yaris both are relatively easy. The "Drive Shaft" section of the service manual explains the process (download from the Micro Image forum: http://www.microimageonline.com/foru...32-YARIS-FILES).
Basically, you drain the tranny, remove the wheel, remove the axle nut, disconnect the tie rod end, stabilizer link, and ball joint, pull the steering knuckle off of the shaft, and then pop the drive shaft out of the tranny. When I did Crashy's, the hardest part was getting the axle nut off.
As for replacements, I bought a junkyard one for $50 off ebay that was in perfect shape.
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
Add another hard drive to a laptop? CompanyXPaladin Off-topic / Other Cars / Everything else Discussions 4 11-23-2008 12:18 PM
external hard drive questions Shroomster Off-topic / Other Cars / Everything else Discussions 10 11-23-2008 04:46 AM
Anyone know how the passenger seat detection system works? rage2 DIY / Maintenance / Service 5 05-12-2007 07:22 PM
