#577 |
Did you use new bearings for your build?
#578 | |
Awesome!
Drives: 12 Yaris/07 yaris Join Date: Dec 2010
the higher a/r will easily add top end and help increase boost, you will lose spool, as in it will take a few more revs to spool the turbo.
id go with a .63. Quote:
#579 |
C'est la vie
Drives: 2009 2 door hatchback Join Date: Aug 2009
Yes, I bought toyota bearings. One of them came on a slow boat from japan. Could not find one in entire US. Also replaced the rear main seal and two O-rings between the block and upper oil pan. And U will need another two O-rings between the oil pump/front cover and block. Dont forget head gasket, valve cover gasket, intake and exhaust manafold gaskets.
#580 |
C'est la vie
Yes thats the plan. And I definitly need the external wastegate. The internal gate does not move fast enough when cranking up the boost.
#581 |
That's closer to my set up -- you'll love it.
#582 |
C'est la vie
I am having trouble tuning for above 16psi with my FIC. I believe it is ignition problem. Above 16psi I am getting a nasty missfire between 3500 and 4500 where my boost is getting to 18-19 psi. Still working on it, I havent givin up yet. I will try to retard timing a little more at high boost to resolve this. Any tuners out there run into this? I noticed that tuning with the FIC is getting tough as boost climbs. My AFR's are fluctuating a lot within the same cell on my fuel map.
#583 |
has anyone else ever gone this far with an FIC? 16psi is starting to get pretty serious.
Or try some simple things like close the gap up a thou or two on the plugs |
#584 |
pimp, what gap are you using, and which plugs?
#585 |
C'est la vie
I am running NGK BKR7E plugs gapped at .020"
#586 |
Have you tried a bigger gap? .020" is getting pretty small compared to the stock at what, 32 thou? It's possible the spark isn't big enough to ignite the mixture properly
#587 | |
05 Scion tC allmotor 350+ hp 9.34@144mph 05 Scion tC sfwd 880hp 9.96@147mph 05 Scion xB 280hp 12.97@104mph 07 Toyota Yaris 357hp 12.80@107mph |
#588 |
Mr. 155 and climbing
So Brian raises a good question at least from a curiosity standpoint...how many PSI of boost is the AEM FIC supposedly good for?
#589 |
#590 |
#591 |
The AEM has a built in MAP sensor
#592 |
![]() ![]() ![]() ![]() Drives: Yaris Sedan 2009 Join Date: Sep 2010
Pimp...I thought you were standalone man its crazy a fic at that boost haha looks like it works pretty great for just a piggyback...
you make me double think about going standalone...
Interior:ALL red, black roof Exterior:RTX scorpion painted GOLD, side and rear visor, oem spoiler, MI mesh grill, Hella supertone horn, RS badge, Vios badge, CF pillar, Led mirror cover, fog light HID 3000k, Projector retrofit HID 8000K Performance :MI CrankPulley, Tein springs, UR and TRD bar, TURBO IN PROGRESS Audio : Pionner DEH-80PRS, HAT L1V2, PowerBass 1100.5X 5 channel amp
#593 |
#594 | |
C'est la vie
Also Im going to need a new boost guage. Also I seriously need a external wastegate setup. I need to organize a Turbo 5K walk for my car. Gotta raise funds.I called Ptunning about the turbo manafold I was looking at, and they said they have none in stock and it would take at least a month to make one. I was a little dissapointed. I am holding off on the order for now and rethinking this. |
| Under $2500 Turbo Kit w/Intercooler coming soon! | cdydjded | Forced Induction Forum | 58 | 09-23-2007 02:02 PM |
| turbo manifold build... | joey1320 | Forced Induction Forum | 4 | 06-30-2007 02:26 PM |
| ZPI to produce yaris turbo kit and exhaust | turboyaris | Forced Induction Forum | 15 | 06-09-2007 01:24 AM |
| ZPI soon to release their turbo kit | turboyaris | Forced Induction Forum | 10 | 04-26-2007 02:52 PM |
| ZPI to produce yaris turbo kit and exhaust | turboyaris | Forced Induction Forum | 30 | 04-04-2007 02:10 PM |
