Why is the 2012 rated 2mpg higher than 2011
And below. Is it a tire difference or did the body change effect the aerodynamics?
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
Probably cuz they have more prius' they rather sell you. Before there was only one...so they rated the yaris low mpg to try to get people in the prius.
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
no show, no go :(
from what i've read, it's due to better aerodynamics...
![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris sedan Join Date: Jun 2007
Quite likely, b20vteg. It doesn't take a lot to change the aerodynamics, and the results are often dramatic. All one has to do is follow F1 to learn that...
play every day
It just might be the 2012's new exhaust manifold design...
Modded Moderator
Wow that is different!
![]() ![]() ![]() ![]() Drives: 3-door hatch Join Date: Oct 2010
Oooooooo... Will that retrofit as a straight bolt on to the 2011? In the Miata world, a popular mod is to retrofit a 2001 tubular exhaust manifold for the 99-00 cast iron manifold. Works about as good as an aftermarket header but looks bone stock to the inspectors.
play every day
Yes, it will.
I know because I had replaced it with a Weapon R header that was listed for 2007-2011 models and it fit perfectly. |
| 2012 Camry | Kal-El | Off-topic / Other Cars / Everything else Discussions | 26 | 10-02-2011 09:20 PM |
| 2011 vs 2012 | beebosaur | New YARIS Purchase Forum | 11 | 08-27-2011 08:37 AM |
| First Drive: 2012 Ford Focus | Kal-El | Off-topic / Other Cars / Everything else Discussions | 18 | 02-25-2011 05:41 PM |
| 2012 Vitz from the 2011 Tokyo Auto Salon | CTScott | Third Gen Yaris General Discussion | 14 | 02-10-2011 08:06 AM |
